Have a 2001 transporter cab chassis. 250k.Manual.Lately after starting up 1st and second gear engaged leads to a loud noise then disappears in higher gears. Thrust bearing?????????
noise noise and more noise.
Dual mass flywheel. Get it sorted before the thing explodes and destroys the gearbox.
Check the rear engine mount before taking the box out, but I'd still reckon the dual mass.sigpic Camden GTI Performance. VW / AUDI Specialists
With a little research it seems that there were DMF's fitted from around 2000 on link here which is interesting http://www.youtube.com/watch?v=DHapjYefAt4 This ones in a Golf but same thing http://www.youtube.com/watch?v=DHapjYefAt4Last edited by Sunny43.5; 28-04-2013, 01:16 PM.
Yeah bit more loading in the lower gears i suppose, ive had to angle grind a hub off once as it was seized solid and couldnt access the bolts. Is bit clacking? if the answer is anywhere near yes then DMF
JmacAlba European
