Hi all
I just took the plunge and had fitted the ZENEC unit.
The brochure makes note of the RDS tuner quote"with automatic station search, 30 station memory (18FM/12 AM) and best station memory. It simply doesn't work. the sensitivity of the AM receiver is crap also, perhaps this is the reason that the system is not grabbing the stations. I had the supplier give me all sorts of bull.... reasons but explained that I had spent my life in electronics, a lot of it radio. They eventually advised me that "because there is no AM in Europe, the function had been removed"!!! We tried another new unit with the same result so it does appear that the function just doesn't work on this model despite the claim. The stations have to be scanned in manually and saved. OK if you don't travel. I do a lot and the function gets a lot of use, or at least did. Another function that is claimed is the GPS turn info repeated on the MFD display in the centre of the gauge cluster. They tell me that in a few weeks they might have a patch to make that work, we'll see.
The distributor in Sydney told the supplier that if they got enough complaints about it (20 was mentioned) that they could go to the manufacturer and possibly get an "upgrade" to include the station search facility.
It would be good to get this posted across all VW models as the unit is common to lots of models. Not sure how to do this.
Any comments appreciated.
Peter
Peter
