Hi all, my 95 T4 2.5 petrol is really getting difficult. I am frustrated.
It misses and sometimes stops only to go again straight away. The pump relay clicks on and off at times with the pump operating as normal (ie 2sec run) I have traced and pulled all wires in and out of pump and relay and can't simulate the fault. I cleaned the relay points it went well for a day so I replaced the relay took it for a test drive 1/2 km miss, stall, start -got home. Pulled out the pump ran it off a battery no problems.
I could be experiencing an intermittent ignition fault but dont know where to look. I recently had the coil pack tested by Injectronics P/L and it was fine. has any one got a fresh test or idea
Regards Eddie
Regards Eddie
