Hi T4 philes. On my new second hand (2004) Tramsporter, the clutch pedal makes a loud "click" as the pedal is coming up after engaging the clutch.
On closer inspection it seems that the bracket holding the master (clutch) cylinder travels backwards when the pressure is applied to the mastercylinder; thus slightly misaligning the push by the pedal to the master cylinder; ie its pushed sideways as well as down. Seems this has damaged something inside the master cylinder as you can "feel" the click by applying your finger tip to the cylinder.
Seem to recall someone on this site saying there was a weak point about the T4 clutch pedal which can be fixed by welding a bracket somewhere.
Anyone familiar with this? Anyone done it? Anyone with details of this bracket and how best to weld it in?
Thanks in anticipation
rory
rory
