Slight increase in oil level on dipstick;- Multivan TDI
  • Slight increase in oil level on dipstick;- Multivan TDI
    Hi,
    Anyone noticed a slight increase in the oil level on the dip stick between servicing? I have. Could it posssibly be Diesel slightly diluting oil? The sniff test of oil on the dipstick would suggest so.
    No coolant issues (milky oil).
    Any thoughts appreciated.
    Cheers, Scott (2008 Multivan TDI)
    How is the performance, fuel consumption, smoke at the back of the van?
      There is a slight jerkiness at low RPM ( approx 1300RPM to 1500 RPM) speed cruise. Otherwise performance and fuel consumption normal. No smoke.
      Cheers, Scott
        How long are your trips? If you do many short trips you can expect more soot in the oil, which could slightly increase the oil level. You could always get the used oil analysis done on your oil, just to be sure.
          Transporter, yes plenty of short trips - being city bound most of the time. It is due for an oil change in about another 3000 ks.
          Even in the city it does get a good fanging whereever possible and on the highway from time to time. The Jerkiness at cruise and a slight hestitation when the auto re engages when accelerator is totalling released and back on again are still under investigation. At this stage not sure of it is auto or engine. Feels smooth when running in neutral. Unless it is a slightly suspect injector.
          I am waiting on my V-checker VAG Pro to arrive so I can do a preliminary fault test.
          Thanks, Scott
            Hi Scott
            I have just had 2 years of chasing this problem. Oil analysis proves it is diesel. VW warranty replaced tandem pump, complete cylinder head & no different. Then they reprogrammed the ECU & it was fixed for a while, now it's happened again.
            Here's an experience that I found appropriate:
            hi there , iv got a mazda 6 diesel 56 plate , my dpf light came on last year , checked my oil level and it was way above the max level but there is also a x marked on the dipstick further up and mine was above that . took mine to a independant mazda dealer he did a regeneration clean. reset the light job done. keep an eye on your oil level, as if you do only short journeys it clogs up the dpf filter which causes unburnt diesel to be dumped into your oil sump , if you look on your dip stick you have min and max then further up is a x mark , make sure you change your oil before it gets to this point as it can blow your engine. dont worry about your oil level rising its doing its job , taking your car out for a spin 45min or more once a week helps stop it rising to much , thrashing it dont help its getting the car up to working temp that helps burm the filters clean ,make sure you use fully synthetic oil aswell, hope this helps
            I am doing an experiment to get rid of the STUPID "dpf"
            Jim
              Hi Jim,
              Thanks for the response. I am keeping an eye on it until the next service. It is just above Max on to the bulging shaped section. Had few trips recently (and a few Italian tune ups) and working hard in tiptronic mode through the hills. Even in the city, it gets a work out. The oil level does not appear to be increasing any further, and other than slight lumpiness cruising along at 1500 rpm, is running as normal. Its got me thinking whether it was slightly overfilled last service, but I just remember to be quite honest!
              I recently bought a v-checker pro and there are no faults indicated; although i am not how sure useful it is as I pulled the MAF plug and few other sensors and still no fault found!! Although it does perform various ECU checks such checking speakers!, ABS pump, dash warning lights, instrument checks, etc etc.
              I reckon I will need to get the oil change done and ensure the dealer doesn't overfill and then monitor oil level very closely. The slight lumpiness (may be a slight miss) has got me a little baffled; hope it is not a slightly leaky injector spray pattern.
              DPF regen seems to be doing its job when needed, although I haven't noticed it for couple of weeks. So I am keeping an eye on this.
              DPF was replaced a few months ago as the internals had broken up inside triggering the glowplug warning lamp (which is a warning lamp for a number of faults; and can be verified by unplugging the MAF for example).
              Thanks, Scott
                Just a question for the poor old buggers like me , do VW tell you either when you buy the van new or in the owners handbook about the DPF ? as it seems to be a bit of an issue with vans that are city bound .
                  People read the review when they buy $195.00 pocket camera, so I don't expect that anyone buying car wouldn't read anything about it.
                  It's in their advertising booklet, it gets also mentioned in the reviews which buyers read before they buy vehicle. I don't know if there are many people who buy $50,000 + van and don't read whatever information they can reach.
                  So, yes I can say that everyone buying the modern vehicle is aware of the DPF, though they probably don't mention that the technology is new, can cause the problems and cost you money. Just like every other new product that we buy.
                  People propbably don't ask the right questions, when they buy the things.
                    The manual does have section on the dpf. A pal just got a new Audi & it's in there.
                    It says if the light comes on operate above 2000 rpm for 15 minutes under load.
                    They do not mention possible oil increase, but perhaps Mazda do admit it??
                    Which leads us to the question of the special oil for these engines.
                    I wonder if it's designed to accept a certain amount of diesel dilution??
                    I have a history of oil analysis on my engine & I'm itching to join a class action against these manufacturers for supplying a defective product that the dealers don't even understand.
                    Jim
                      The manual for my 2008 model has a section on DPF. Note the DPF light has never come on in mine with a sooted up DPF. Regeneration has always occurred as expected. The DFP collapsing is apparently unusal. I don't even put myself in the category of being a timid driver. Even in the city, mine gets warmed up sufficiently! I actually notice regeneration after a long round trip of a few hours on country roads.
                      Regards,
                      Scott
                        Guilty as charged , but does everyone know what some of these things actually mean if they are going to impact on your driving pleasure later on ??? DSG DMF DPF ??? I only found out what DPF was through this forum !! sorry but it is a case of the manufacturers maybe do not make it completly clear in the owners manual . My situation precisley an auto that does not require servicing / NOT one single solitary word given by salespeople or owners manual about this "Feature" Sealed For Life . End of my imput on this particular subject .
                          Yeah, you're right. It's almost like, you live and learn.
                          Almost everything we buy today needs to be questioned and sometimes the questioning goes so far, that many that are questioned could get offended by the questions we have, but there is no other way. It's probably easier to find the info today than it was in 2005 or 2006 also mainly because the T5's were not long enough on the road for the problems to surface up.
                          I don't want to rub anything in but, I use the rule that; if the service interval appears to me too long, I at least halve it. If it says lifetime fill, I change the fluid every 20,000km, at least in the gearbox, diff and P/S. The coolant every 2-3 years. In the case of the A/T, the oil change every 40,000km should significantly extend the life of that A/T.
                          I hope you get your A/T sorted out.
                            Thanks Transporter for your support I just won,t roll over on this one I will keep digging at VW I know its probably hopeless but if you don,t try you will get nowhere . I see you are in the auto business with 32 years experience so you would obviously know about these things but you have to put yourself into the noob shoes . IN 2004 nobody was talking out loud about the service non capabilities of the VW ,s autos so how were we supposed to know ? there are only so many questions that come to mind when you purchase a new car .
                              That's what I meant, in 2004 the T5 was new on the road.
                              Sent from my GT-N8000 using Tapatalk 2
