At first it seemed to cut out and the light on the dash would dissappear for a moment when the blinker arm was moved, but after prodding around the blinker arm I cannot get it to turn on at all.
I got an auto electrician to remove the steering wheel and check the wires from the cruise lever but they found nothing wrong. I then got a vag-com printout for the van and it came up with the following:
Address 09: Cent Elect
3 faults found.
00895 - Cruise Control Xwitch (E45)
008 - Implausable Signal - (intermittant)
00905 - Fuse for back-up lamps (S40)
014 - Defective - intermittant
00967 - Left Turn Signals
011 - Open Circuit - intermittant
My question is, which fuse is being referred to as S40
Is it anything to do with fuse 9 in the C fuse box as seen here: http://www.vwwatercooled.org.au/foru...ion-64343.html
9-Fuse -5 A-Steering column electronics control unit -30 J527- Adaptive cruise control unit -J428-
Does anyone know which fuses are involved with the cruise control or anything else I can check?
Thanks in advance
Brian
3 faults found.
Thanks in advance
Brian
