kept studying it all day. mayby it spins other way to create vacuum for brakes. that would make more sense. but that would pressurize oil in engine.
its dead, and vw killed it
i have '04 2.5 tdi t5. ive had the typical starting problems for 6 months. vw insisted that changing the crank speed sensor would fix it even though i told them it wouldnt. since changing the sensor engine has been running rough.(first time its ever run rough since new) slowly getting worse till the point where i couldnt go in 4th gear cause not enough power. changed fuel filter just incase i had bad diesel. it now wont go at all. i also noticed since changing crank that it doesnt blow its normal diesel smoke. i can floor it and absolutly none. i have heard that vw recently has been changing codes secretly to try to cut emissions, then i thought, what better time for them to do it than when changing the sensor, and they will say less smoke cause of new sensor. but when the car was new it blew more smoke than now.
any thoughts on this
Who changed the fuel filter? You or VW?Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
im trying to fix the starting probs. vw told me for 100% certain changing sensor would fix it. who am i to question them. and until they changed that i couldnt convince them to consider anything else.
i tried a few independents, but since vw stuffed it they dont want to touch it. 1 guy did and says he has no idea what they done and hes too busy to look at it for 2 weeks. that gives vw 2 weeks to hopefully find what they done
Originally posted by jfoldbar View Postim trying to fix the starting probs. vw told me for 100% certain changing sensor would fix it. who am i to question them. and until they changed that i couldnt convince them to consider anything else.
Now, excuse me, I have to merge all your threads you've started, because they're on the same topic.Last edited by Transporter; 21-07-2011, 09:15 AM.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
uuummm, whats your point transporter?. and how do you say my posts are on the same topic.if the topic is problems then sure, but arent almost all topics on problems people have. are you saying i should not post queries when i have issues with my car. how else can i do research?
quote "they've tried to fix the van that was already broken "
they changed a part (crank speed sensor) that was not broken. and now i have more problems than before.
sure i agree that in the process of trying to find a problem then as a process of elimination to find the cause then they must start at the least intrusive and logical and work up. but that is my point, they changed an illogical part. and if it wasnt for my research on sites like these then i would never have leaned about the tandem pump and asked them to test it finding a real fault. while i acknowledge mayby it did not fix the problem either, it at least makes sense that it could be,
i am not annoyed at vw that it wont go at all after changing fuel filter. i realise they had to try that to eliminate a possible cause.all in all i find them quite good. it is quite frustrating though that they dont know what i pay them to know.
this is also the first vw i owned (expected them to be more reliable) and first car i owned that i did not work on, so the first time ive ever been to a mechanic. am i expecting too much?
do you think 200k is a good run? (it was not trouble free motoring though) i dont. mayby some do though
Ive seen a few starting problems in those engines.
Injectors, lift pump, bad fuel. Changing your filter is not going to eliminate a fuel issue. The van i fixed had contaminated fuel - water. The water made its way to the injectors and started to rust them. After a long period of time they stopped working. I sent them out to get serviced and they said they couldnt even get 3 of them to fire.
It wouldnt surpise me if an injector has failed similar to the 2 litre diesels with injector problems.
Originally posted by jfoldbar View Postuuummm, what’s your point transporter?. And how do you say my posts are on the same topic. If the topic is problems then sure, but aren’t almost all topics on problems people have
Originally posted by jfoldbar View Postare you saying i should not post queries when i have issues with my car. how else can i do research?
Originally posted by jfoldbar View Postquote "they've tried to fix the van that was already broken "
They changed a part (crank speed sensor) that was not broken. And now i have more problems than before.
sure i agree that in the process of trying to find a problem then as a process of elimination to find the cause then they must start at the least intrusive and logical and work up. But that is my point, they changed an illogical part. And if it wasn’t for my research on sites like these then i would never have learned about the tandem pump and asked them to test it finding a real fault. While i acknowledge maybe it did not fix the problem either, it at least makes a sense that it could be.
Originally posted by jfoldbar View Posti am not annoyed at VW that it won’t go at all after changing fuel filter. i realize they had to try that to eliminate a possible cause. All in all i find them quite good. it is quite frustrating though that they don’t know what i pay them to know.You need them as they need you and that's it, nothing more. So I call it even.
Originally posted by jfoldbar View PostThis is also the first VW i owned (expected them to be more reliable) and first car i owned that i did not work on, so the first time I’ve ever been to a mechanic. Am i expecting too much?
do you think 200k is a good run? (it was not trouble free motoring though) i dont. mayby some do thoughPerformance Tunes from $850Wrecking RS OCTAVIA 2 Link
