Hi all,
In chasing down a mysterious whistle that eventually was narrowed down to being present when the heater fan is on, I discovered a couple of odd things:
1. When the heater fan is on the engine fan is on as well. I can understand this when the a/c is on as there is a need for air flow over the a/c condensor in front of the radiator but, I cannot see an advantage at all when the heater is used.
2. When the a/c was fitted (I believe all were fitted in Australia) the original pipe to the left demister vent is cut and left half open (I'd like to insert a pic here but I do not have permission?). This means a big leak of air bypasses the a/c evaporator & heater core. This is so slack of the a/c fitters - I've never seen anything like it.
Has anyone else noticed this?
I suggest checking the a/c behind the glove box and blocking the remains of the old demister vent to improve fan efficiency (for free!)
Does anyone have an appropriate fix for the engine fan wiring? I assume that it was easier to wire both fans together like this rather than wire the engine fan to the a/c only (as well as the temp switch).
By the way, removing cleaning and lubricating the heater fan has not fixed the whistle - it must be in the engine fan.....all I have done so far is make more work!
Regards,
FarmSyncro
Regards,
FarmSyncro
