Thanks for the tip. My brother in law is great with mechanical/ technical aspects so I will definitely be asking him to fit it for me! Less frustration all round!
2006 Multivan T5 Highline...with NO radio!!!!!
Just a quikie here I have imported quite a few chinese units not only the ones I mentioned but quite a few for friends and relations , finding a double din one that tilts downwards in a 7inch is all but impossible to find . If you stay with a single din with a retracting 7 inch screen no problem as they can be set for whatever position you want . Yes the T5 radios are mounted high on the dash and sunlight is a real problem I made a very simple eyebrow shade for mine works a treat even in the middle of the day and looks quite good . Howard
Originally posted by Transporter View PostI would actually prefer the unit that will allow the screen to be tilted, because of the bad angle of the T5's dash that makes many screens difficult to watch. I have the 7'' screen that is GPS and reverse cam on the top of the dash and despite the screen has a shield, it is still hard to see anything on it in Summer.
Kenwood makes the 6.5" unit with the Satnav that could be tilted the right way for our dash, but it is expensive.
sorry stinky nappy just saw the bottom of this thread enjoy the sat nav.
i am actually looking for the same as stinky. just bought off the brethren and need a sat nav. priced a pioneer and kenwood today. does anyone know how they compare and if i can get a better idea for the multivan without paying a fortune?
In my old T5 I had a Pioneer AVIC BT900.
Dont get one. The bluetooth is hit and miss. Sometimes it works, other times it doesn't.
The screen is nearly impossible to see when the sun is on it. Compared to the RNS510, which you can read the screen when the sun is directly on it.
With the Pioneer, you will need to buy the CAN adaptor.
The GPS function on the Pioneer ****s all over the RNS510. That is the only good thing on the Pioneer.
I'm using an Eclipse AVN726EA double din
Not cheap, but I've always found Eclipse to be very good in the sound quality dept
Blue tooth is almost perfect, but certainly good enough to be happy
Sat nav is excellent, only downside is updates are around $130, and they take forever to come out
Day time in the sun is readable
At the time it was the best I could find without getting a second mortgage, but I'd hunt around more if I had to buy something now
M
I installed a Kenwood about 12 months ago. The only problem I have is the AM radio doesn't work because there wasn't any way of connecting to the antenna. Otherwise the Bluetooth has been mostly great, although I can't get the voice commands working to my Blackberry, but the connection is rock solid, and the sound is fine with the standard speakers, as long as you don't want high end.
I really like the Kenwood satnav, as it has Garmin software in it. I'm just about to attempt an upgrade, so we will see what happens then.Golf V TDI 2005 - SOLD
Volvo C30 D5 - I've got a hat as well!
Multivan Highline T5 TDI 4Motion 2005
Hond Civic VTI 2001
Just to brag here , as I said earlier we have two chinese double din head units in our T5,s . Now my van is used for my business fitting sunroofs and servicing them onsite , so I do a load of driving during the week . Now I am a music freak if you are ever stopped next to me at the lights here in Brissie there is a good chance you will feel and hear my music in your own car !!!!. The unit,s installed have built in amp but its only very low powered its okay if you are just hooking it up to stock speakers .
No brother not me 2 x 12 inch Pioneer subs behind drivers seat tucked neatly behind my commpressor 2x pioneer tweeters mounted into dash where the originals were plus 2 x 6.5 inch two ways in the doors , the front speakers have their own amp connected to the head units front RCA outputs and the subs to their own amp from the rear RCA outputs .I am also using Maxx Bass line driver for the extra ooomph . AM FM radio is okay but lacks a little reception strength CD DVD MP3 disc player spot on ,Bluetooth syncs with any phone for phone and music playback plus I was able to add an external mic for the phone as the unit has a built in mic which was too far from driving position .
IGo GPS runs in the background regardless of what function you are using and as each command is given the map comes up on the screen plus TV tuner Aux inputs and touch screen . Howard { growing old disgracefully }
Crikey, that's some serious stereo accessories there Sunny! Whilst I love my music, these days I am surrounded more by Playschool CD's in the car (with 3 kiddies 5 years and under and the 4th on the way!), so nothing flash needed, just plug and play!!
It is amazing to hear what people are popping in though, and I am loving this forum. Going to have to head on a search through the forum chats this week to learn about roof racks which will be the next item to tackle...
Kenwood new nav system
I did forget to mention, that the guy that quoted me for the Alpine sat nav system said that the Kenwood was the only one that had the right tilt angles for the multivan, but they had had some problems with the units, so they were due to release a new version in about 1 month. Don't know if that helps anyone else looking and considering a Kenwood.
I take it as you succeeded. Is there a fascia that will blend in the round corners of the RNS ?Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
To answer the question regarding the head unit we have they came from a company called SZWaywell they are well known on the Golf threads . Since buying the units we have from them I have tried another couple of companies . My current favourite is a company called Easyrising here is the link to one of their VW units when you are looking make sure that the letters AU are after the model numbers as this indicates Australian maps and if fitted the correct DVB tv frequencies . I can tell you they are very good to deal with fast service once payment received the unit arrives within 5 or 6 working days . The Waywell units are also very good as I described but technology has changed so fast that we are going to update ours to these new ones from Easyrising . My son has a single din model in his T4 it has a slide out adjustable 7 inch screen , it is a great unit with touch screen operation and function change by just sliding your finger either across the screen or up or down to change settings just like an Iphone screen . Howard PS if you scroll down to the bottom of the info screen on the model I have sent the link for you can see that they also have CAN Bus adaptors as well . This is the one I am thinking of upgrading to it has the square corners to suit first model T5,s http://www.ebay.com.au/itm/ES848AU-7...o%3D%26ps%3D63 I am not sure about the later T5 hole size is it square with round corners or is it a tapered unit wider at top than bottom .Last edited by Sunny43.5; 06-06-2011, 05:41 PM.
