Had a go at welding up a cracked exhaust manifold today,got it from my local vw mechanic was off an 06 that they replaced at 110k was full of cracks, one flange was cracked half way around the turbo flange at the flex joint had a cracked 80% around right through the center of the weld and two that had started beside some welds.
It welded very nicely using the tig and 316 filler rod, got to hot when welding the turbo flange and melted a hole in the very thin flex joint steel so now it definatly is rubbish.
My local mech is saying spend the money get a new one, $1100 got a quote today from VW, I would much rather keep that money and try a welded one unless the new one has been improved to go alot longer than the 45k I got out of mine.
