watercooled engine mountings for combi
  • watercooled engine mountings for combi
    does any body know if u can some how adapt a 16v golf lump on to a combi or beetal gear box, ive seen i 1600 8v on the back of a off road buggie once and was wondering if a 16v conversion is possible, why, because i just might consider doing up a combi with a 16v donk, should be sweet if possible
    and would u need to make new engine mounts? or are there kits for this sorta thing, any info would be super
    the golf is not dead.
    I think you need to talk to stijn, I got some 16 V parts from him several years ago, he does a load of crazy mods...
    that is the 16 V into a notchback, so he must know something about hooking up a watercooler to a type 1, 2 or 3 transaxle...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
      The blocks and engine mounting points are the same on 8v and 16v motors, so if an 8v is possible, so therefore, should a 16v. Why you would waste such an engine on a vehicle like that I dunno, but good luck.
        so i can cruze around in something real old school like these and carry more than one person unlike the golf and do crazy van nuts.... tuff
          hi guys when i first visited the vw motorsport factory they were fitting brand new vr6 and 16v motors in the back of 4x4 tranporter t3's it was a very costly exercise by german standards then but a hell of a lot more affordable today...my brother runs a 2.0 16v in his off road buggy which is married to a 2.0 litre kombi box stuffed full of different ratios...goes hard all day long and doesn't complain[the ideal woman] cheers steve
            theres a guy on the gold coast that makes engine adapter plates ive fitted commodore engine to a combi box with one of these with no problems just had to get a flywheel made
            ill get the guys no for you but may take me a while
            78 Mk1 Golf
            62 beetle still 6 volts
              yeah ive seen a karman ghia with a 3.2L porshe motor in it using a porshe box though, that required a massive conversion but made it go like the clappers, ive recently found some one who does this sorta work in quenbeyan called "progress motors" these guys are good they run a rally evo 7 and GT3's cup cars and stuff, , they can get all the parts i need no worrys just waiting on a price or he tried to convince me he wanted to build all the adapters and respray and smooth the body etc etc and he was keen as then he said there will be a 3 month waiting period, wooooo dude i havnt evn got the van yet so yeah if ny body want to give me free stuff this is where im going to get it done as it is real close,
              commodore engine! sweet... V8 or six? the 8 would be crazy and tuff in a van
              would u have to streaghten the 2lt vw box or is swapping the gears satirsfactory does any body know what clutch to use?
              i checked out that notch back link (roccodingo) thats what i want but in a combi and EFi still sweet, ,he bought it with the motor allready in and mounted up, surely it cant be that hard, its only a engine!!!!!! right.
                we put a 6 in the kombi
                we also put a rotor in a type 3 squareback matched to a standard box with a 3000lb clutch (runs off the speedo in 2nd gear apparently)
                78 Mk1 Golf
                  Did you see the watercooled double cab down the bottom ??, he installed a 16V + turbo if I remember correctly, sold it to a dude in UK.
                  Cheers,
                  Grant...
                    nah didnt see the combi link , a rotor, 13BT please, would be good cuase there small not bad conversion
                    i want one now!
                      a beetle gearbox is quite capable os working a v8 the adaptors are easily aquired to fit anything
                      i had a 1971 kombi with a 1600 upright motor with a toyota supercharger fitted big torque
                      today is not a rehersal for tomorrow so do now and do it right
                        Yeah!
                        Good to hear from ya, Greedy. Your first post is a good one!
                          I ran a 1.8 16v in my 62 single cab for years until I found my caddy.It ran late T2 irs and disc front end. Everthing from the engine mounts to the radiator and plumbing has to be fabricated.Ther are some pics around of it at Wakefield on a Porsche sprint day, lots of fun.
                          Widebody Cayman S Turbo, 83 ur Quattro
                          2000 996 C4 cab,12 Scirocco R OEM+ STG2+
                          72 914 (3.2S boxster pwr), 92 G60 Corrado
                          76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
