Touch Screen T6 Multivan
  • Touch Screen T6 Multivan
    The touch screen on my 2019 Multivan has gone belly up - fortunately not the remaining screen facilities.
    The issue has been referred to a local specialist, who's quoted $1400-$1700 for rectification.
    Anybody else had this issue? Is there a more cost-effective method to change between AM & FM radio channels, thanks?
    You need a replacement head unit (unless you can find someone who can replace the touchscreen parts) https://vwcentral.com.au/products/ge...ok-caddy-jetta
    B9 Audi SQ5
      You’re not alone — this seems to be a fairly common issue with the 2018–2019 Multivan infotainment units. Often it’s just the touch digitizer that fails while the screen itself still works.​ before spend to much try Restarting the unit (hold the power button for ~10 seconds).
