Hi All,
I have a 2003 Transporter TDI manual fitted as a camper that has developed a loud rattle and vibration. It came in with a bang that indicates something broke.
The engine code is ACV, has done 147K, timing belt done at 120K. I had it from new.
I have checked the exhaust manifold but cannot find a crack or leak.
I checked the intake and found it full of grease and was shocked.
I also checked the injectors by cracking the pipes at idle and noting a slow down, off beat and then pick up when sealed.
I tried to check valve clearance but found cam direct on buckets.
How is the valve clearance checked?
I suspect the dual mass flywheel is the culprit.
The flywheel can be rotated about 10 mm either way by screwdriver through the inspection hole near the starter motor.
Is this normal?
Neil
PS, 2 of us newbies have recently registered with near identical user names.
If it causes confusion I will gladly reregister, the other t4camper has a heap of cred under that name in the UK.
Is this normal?
Neil
