Lift up roofs
    Fairly obvious that any wiring for the tail lights etc would probably just be moved sideways to the very outer edge at the sides , the factory wiring is along the left side and after conversion they would just refit it . As for interior lights side mounted would be done or some roof mounted with custom wiring to supply power with roof extended might be an option . Air vents I am afraid would most likely be lost as there is ducting through the roof cavity that would not be compatible with a conversion .
      Thanks for the quick response, always thought there would be a compromise
      Sent from my SM-G935F using Tapatalk
        Has anyone done it to a Multivan that could share photos?
        Can only find the VW California's online which are made from factory.
          Here are a few photos
          Ducting and lighting re-routed but airflow is not as strong to the very rear... that said the Multivan ex-factory does not have a roof outlet in the very rear.
            Wow thats great.. Thanks for the photos..!
            Is the bedding comfortable on the pop up roof top?
              Sorry, still on this post... What would a flip top or pop top cost nowadays for a t6 multivan? Still looking at 8-10k?
