It is not a DPF.
Anyway when you start up in the morning do you get characteristic diesel engine smoke fumes from your exhaust or you smell nothing. If you smell nothing than you have DPF. If you drive normaly and than take of realy fast from the traffic lights is there cloud of gray/black smoke behind you? If yes than you don't have DPF. Further more DPF fitted vehicle would have exhaust pipe so clean that when you put your finger in the tail pipe it will be clean. Not the case of my T5. Also tail gate has some diesel smoke build up on it and rear bumper bar is dirty from the fumes undrneath. Check all these. Like I said DPF should have some wires leading from it. Your picture doesn't show that.
I hope that helps.
I hope that helps.
