T5.1 Multivan Aircon blower motor fault
  • T5.1 Multivan Aircon blower motor fault
    Hi Van lovers
    My 2011 Multivan has developed a fault with the AC blower motor
    The fan wont stop running after the ignition is turned off, sending the battery flat
    I removed the LHS dash to access the motor and unplug the fan, part # 7E6 820 021
    My local auto electical guy said a replacement fan would remedy the problem
    Sourced a replacement fan motor from a wrecker and installed the unit today
    It did not fix the problem, the replacement fan will not shut down either
    Guessing the fan is not the issue here
    Any ideas?
    Thanks Snickerty
    Hi Snickerty,
    That is really odd. Unless it is an ignition related fault?
    I had to replace my fan last week. After trying to nut out Chinese knockoff part numbers, I bit the bullet and bought an oem at $572. Ouch, but got it the next day and installed it. I also had pulled the original out about two years ago greased it to cure a squeaking noise. But it had now failed with on and off running. Not easy to operate on and replace brushes etc, so replacement it was.
    Cheers, Scott.
      Hi Scott
      Thanks for the reply
      Can you tell me who you got your replacement fan from
      My local dealer quoted me $715.00
      Snickerty
        Originally posted by Snickerty View Post
        Hi Van lovers
        Any ideas?
        Thanks Snickerty
        Check out the wiring diagram, there will be a relay or control module that will send power to the fan, hopefully it will be just a stuck relay.
        Sent from my SM-N960F using Tapatalk
          Hi Scott
          Snickerty
          It was Camberwell VW in Melbourne.
          Cheers, Scott
            Hi MIG
            Any ideas where I can get a schematic for the Multi, not sure where to start
            Snickerty
              An update on the blower fault-
              I sourced and fitted a second hand fan motor which did not remedy the fault, the fault was the same as the original fan
              The fan keeps running after the ignition is turned off, often at different speeds
              Unplugging the fan for 5 seconds resets the system
              If you unplug the fan and plug it back in really quick it will keep running sometimes the speed will increase
              I have ordered a Fan resistor to see if that fixes the problem #7L0907521B
                Erwin is the best place to get all the wiring diagrams if you want to tackle finding the fault yourself.
                Here is the wiring for the same-year transporter; I would check pins T5r/3, 2, 1, and 4 to see if the climate control calls for the motor to be turned on.
Name:	Screenshot 2023-02-06 175521.jpg
                  Hi Van lovers
                  Just recieved the replacement resistor #7L0907521B and installed
                  It fixed the problem, thanks to Ebay seller parts_au for an excellent quality replica
                  The factory part is $330.00
                  What I had read about issues with the resistor is some of the fan speeds stop working
                  In this case the AC fan wouldnt stop working and with each cycle of the ignition the fan would continue to work at different speeds
                  At no point would the AC fan stop without unplugging it
                  Thanks for the AC schematic MIG, it helped to understand the resistor was the culprit and not the dash switch
                  A great result finding the fix with a total spend of $218.00
                  I hate to thnk what it would have cost to get fixed at a dealer
                  Cheers Snickerty
                    That's good news. I had been googling for more general information about this out of curiosity, the likely culprits appear to be a stuck relay or a faulty resistor. Scott
                      Is this what you replaced ? Click image for larger version
                        The #7L0907521B is one of these:
                          Yours must be a more upgrade model VW which the part seems different to the ones in our vans .
                            I recently though i might need a new blower motor, then found out the fan still worked perfectly but only on speed 4. Turned out i needed a new fan speed resistor, at the exorbitant price of $ an arm and a leg...
                              I replaced ours with an Ebay one and its still going strong nearly 8 years later .
