Tires.....What to get?
  • #31
    Originally posted by type3sedan View Post
    Hi All, the Michelin Pilot Premacy tyres 235/55/17 103Y mine came with new are 35k old, worn enough to need replacing, and are chipping/chunking off. Anyone else experience this? The Michelin guy said they were not suitable for the car, but that's what it came with!? I have been told there are Yokohama and COntinental alternatives. anyone had any experience with those? I've had to replace two of the Michelins at $495!! and have been quoted $320 for the Yokohamas.
    thanks for any tips
    Don't buy Michelin Pilot Premacy. They will not last.
    So far I've done 30,000km now on the Hankook HP DynaPro 235/55/17 and I will get min. another 30,000km from these Hankooks - they cost me $195 each - great tyres - will buy them again.
    I had Michelin Pilot Premacy before (T5 came on them).
    I wouldn't pay $150 for Michelin.
    Read this thread from begining.
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
    • #32
      T5 4 Motion Tyres
      Hi Thread
      I wonder if you could help me with some advise on tyres for my new T5 4M. It's delivered with Michelin 16' but I would like to fit some off-road tyres because I go bush a lot and is likely to get damage to the sidewalls.
      I also would like to raise the suspension, any suggestions?
      Thanks Peder
      • #33
        I found to get long life with the Michelins you need to rotate them every 7500km.
        I average about 45-47k out of a set.
        1st place Mk3 Standard 08
        • #34
          What size?
          I rotated mine (235/55/17) every 5,000km, kept the pressure up all the time and they still didn't last.
          Hankooks will last me double of the Michelins.
          • #35
            235/55/17---
            • #36
              235/55/17---
              You got really good life out of them, considering that many people didn't get 25,000km out of them.
              You probably drive more on hwy, I do city and hills, many round abouts, reversing and parking. What did/will you buy as replacement tyres?
              • #37
                Originally posted by peder1809 View Post
                Hi Thread
                Thanks Peder
                Hi Peder,
                My 4Motion Trakkadu also came with 16" Michelins (Agilis 51). At 45K they look like going to 70K+ easily. It's strange the variability in experience compared to the 17" Michey's. This has included a 10K round trip to Cape Yorke, and the Batemans Bay off-road trip with the Syncro (T3) group, so plenty of off-road use, and no damage to the side-walls. (Some 'gravel rash' on the rear wheel paint work though I did some pretty fast kilometers on the gravel up there). So I wouldn't rush into changing your Michey's, unless you're really pushing the limits of traction. The extra ground clearance of some higher tyres would be useful, especially if you have the LWB van like mine, but the value argument for these tyres is getting hard to go past.
                On ground clearance, I've found the "King Springs" from Pedders for the rear to be a useful and economical (~$350) addition. Anything beyond that seems to get into big money. Even so, watch out for scraping under the fuel tank on berms & things. I'll be getting my third set of fuel tank straps on my coming service. If any-one knows of a good, economical guard for this area, i'd like to hear of it. I can get the Seikel one through Trakka, but at $2350 it's hard to justify when the straps are only $25.
                Brian
                2007 Trakkadu 4Motion
                • #38
                  Originally posted by Ivo View Post
                  I ended up getting the Dynapro 23's fitted today for $199 each. So far so good but need to test them in a few different conditions first.
                  I have about 25k on these now and I think I will only get another 5-7k out of them.....Not real impressive really.
                  2014 T5.1 Multivan Tuned by Pendle Performance Australia
                  • #39
                    What tyre pressure do you use? I pump mine 50psi fr and re.
                    I also rotate them every 5,000km (rotate the spare tyre as well) I've done 30,000km on them now and will do another 20,000km. My van is fully loaded 100% of the time and we have a lot of roundabouts around.
                    So, they work for me I will buy them again.
                    • #40
                      I run about 48PSI in them. Have not rotated them though.
                      Tyre guy said he should be able to get something that will last 50k easy so will see what he comes up with.
                      Tyres on my landcruiser lasted 80k so compared to that I was feeling a little let down.
                      • #41
                        I have Coopers on my Disco and they have done almost 100,000 - ready to change in another 10K. Not bad - compound is a little hard for brakeing but they are good tyres.
                        Shifter
                        Sadie - 08 VW Dual Cab T5 Transporter 4 Motion (128kW)
                        • #42
                          About 2 years ago when I inquired Cooper tyres didn't have enough load carrying capacity.
                          • #43
                            I have had Goodyear G26 and Hankook RA14 on my T4 over the years and there is no doubt the Hankooks are far superior in terms of handling and road noise.
                            On my T5 I have the OEM Bridestone Duravis 16", which I am about to upgrade. I am going to 17" rims and Hankook RA's this week. $220.00 each.
                            (If you are looking for a full set of oem 16' tyres ,see for sale post forum)
                            Tombi
                            • #44
                              I'm now well past 65,000km on my OEM Michelin Agilis 51 16" on Miyato factory alloy's and still have a fair bit to go. The slight shredding seems to have disappeared as well. Only rotation has been through scheduled servicing.
                              • #45
                                My 2008 Multivan has OEM dunlops (16 inch). Very quiet tyre. Seem to be wearing fine at 15K. No idea what they cost.
                                Regards,
                                Scott
