Tires.....What to get?
  • Tires.....What to get?
    Hi fellas, I have done some searching and reading on here and it seems the Hankook Dynapro and the Michelin Agilis are the most popular. My van has 2 Hankook RA14's on the front and 2 Bridgestones that are leaking and worn out. I plan on fitting two new tires to the front and moving the current fronts to the rear.
    I value safety and ride comfort above tread wear.
    Are there any other brands/models I should be considering?
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
    I put Khumos on the Green T4, and seem OK!!
    Maris
      Tyres to consider
      Kumho KL51 may be worth a look if available in your size. They are intended for "SUV's".
      I've put a set on my partners Lexus LX330 to replace the OEM Bridgestones. The difference was like day and night. Kumho's have a 600 treadwear rating vs 140 for the Bridgestones which would suggest they are hard possibly at the expense of ride comfort and grip but ride improved and grip increased even in the wet.
      I've just put a set on my current model Pathfinder replacing the OEM Goodyear Wranglers and found a similar improvement. Wranglers were rated at 440 treadwear. Ride is considerably improved despite running higher pressures - haven't found the optimum yet. I think they might be a little quieter on most surfaces as well.
      Best of all is the price - $245 each fitted for 265/65 x 17 H rated as opposed to over $400 for the OEM Goodyears.
        I've had Michelin Agilis61 (195/70/15) on my Vito and they lasted 75,000km. Handling was good too.
        Performance Tunes from $850
        Wrecking RS OCTAVIA 2 Link
          I ended up getting the Dynapro 23's fitted today for $199 each. So far so good but need to test them in a few different conditions first.
            I've done 20,000km on 17" Hankooks on my T5 and I can see another 30,000km in them easy. No difference to original Michelins the van came on, exept that they lasted 37,000km and they were to 1.5mm at 25,000km.
            Will buy them again if they would be arround.
              MRL T5
              Which Hankooks did you get? Have just asked for a quote to replace the Michelins, and there was a query over the load rating on the Hankooks not matching that of the Michelins.
              Golf V TDI 2005 - SOLD
              Volvo C30 D5 - I've got a hat as well!
              Multivan Highline T5 TDI 4Motion 2005
              Hond Civic VTI 2001
                Originally posted by shogun2 View Post
                MRL T5
                Hankook Dyna Pro HP 235/55/17 103H Max. Load 875kg max.speed 210km/h. $195 @ BobJane Marion.
                Michelin Pilot Primacy 235/55/17 103Y Max. Load 875kg max.speed 300km/h
                  Thanks.
                  Interesting to know what the price will be today.
                  Hond Civic VTI 2001
                    got Hankook Dynapro HP's on mine ATM.Grips ok.Only done about 10K so far,but the fronts are looking a little more worn than I'd like.Will see how they last.
                    Steve
                    04 T5
                      Do you rotate your tyres evey 5,000km?
                      Also I pump them up to 50psi pressure.
                        On my T4 Caravelle I purchased the OEM Goodyear Cargo load rated tyres. About $200 each fitted.
                        The new Multivan came with Dunlops as the OEM tyre.
                        Regards,
                        Scott
                          not rotated yet, but will do soon.Run 45psi
                          Steve
                          04 T5
                            Latest price on the DynaPro HP's is $235 each. Was offered Michelins and Yokohamas for $500+ each. I can't justify that. Have just ordered four of the DynaPro.
                            Cheers,
                            Hond Civic VTI 2001
                              Cheers,
                              Was it DynaPro RA23?
                              I was told on Monday at Bob Jane that DynaPro HP was not available. RA23 replaces DynaPro HP. I check the RA23 tread pattern and it looks almost identical to HP. I didn't check for differences in construction between the two.
                              Still less expensive than others.
