Still fighting. Took the motor right down to the near bare head, and rebuilt, checking and rechecking every step. Still honestly can't work out which crank rotation is the right one, but am narrowing it down, next effort will be to flip the cam on this current setup, and if still nothing, well it's off to the mechanic, I'm done.
Did find some weird things. On bleeding every step of the fuel lines, I found if you run the lifter pump for the 30sec via VCDS and unhook the return (brown ) line, fuel comes out of the tank via the return!! WTF. There is also the normal pressure in the black VF line as you'd expect, this is very strange. Anyone shed some light on this??? It seems the lifter pressurises both lines???? I had to run the pump, unhook and block the brown return line with my finger to get all the froth etc out of the lines. Also had to bypass the HPFP to get any sort of flow with the lifter through the fuel rail and injectors, I'm getting suspicious on my new HPFP, going to put the old one back on before I swap the cam again, it does seem like something just isn't working as it should. I did take the new HPFP apart and checked it over, but it all seems fine. Even filled it with diesel and carefully bolted it back on, so there's no air bubbles anywhere, but still nothing.
But yeah if anyone can tell me the VW pump should be pressurising the system enough that it gets backflow up the return, then please let me know, does not seem right.....
