Not cool this summer
  • Not cool this summer
    Today, the fan (at a minimum) if my 2007/8 Multivan climate control stopped, without a hint or dash warning. It's not impossible that it struggled a bit before it went belly up.
    How should I go about diagnosing the issue?
    “Heater fan”
    I had to replace the motor on my 08 Multivan a couple of times, reason for failure was always the brushes that wore out, I bought second hand motors of eBay.
      Mine was always the front fan, the rear and middle fans never failed
        SGS parts plus in Sydney
          Thanks, folks.
          Ok, I ran up the climate control. There's a piddling flow coming through all three sets of outlets with the setting on full grunt - and anything else for that matter. Naturally there are no error reports with my basic plug in.
          Anybody able to point me to a diagram that might help me delve into the nether depths of the dash on a 2007 Multivan?
            It is the same as I replied on the the other thread FAN resistor easy fit and cheap from Ebay , whenthey fail the fan only works on extreme low speed or not at all . Heater Blower Fan Motor Resistor For VW T5 Transporter Caravelle TOUAREG AMAROK 870229948632 | eBay
              Is it the same part for a t5.1 multivan with climate control? I had no fan working today...
                The resistor is inside the front of the fan box just under the dashboard LHS , I would imagine if you have problems with front only outlets that's the first place to check it should be the same across all models . New link as that old one does not work anymore .Heater Blower Fan Motor Resistor For VW Amarok Touareg Transporter 7E0959263 New 870229948632 | eBay
                  Thanks mate. Ordered one!
