T5 squeaky drivers door
  • T5 squeaky drivers door
    I couldn't find another post on this.
    Have had a noise for a long time when opening and closing the drivers door.
    Have sprayed everything without much improvement.
    Then saw the below video clip and realised there was a cap that needed to be removed before lubricating. All fixed.
    In my defence it is all painted white so doesn't stand out (to me) that there is a cap.
Name:	Drivers Door Squeak.PNG
    __________________________________________________ __________________________
    VW Transporter T5 MY10 Van M 6spd 2.0DT 103kw White. Long wheel base. Standard roof?
    Yes, it should be done every time the van is serviced. Also don’t forget the sliding doors they need lubrications as well.
      did mine the other day, after it started squeaking too
      Steve
      04 T5
        Mine broke completely off on the driver's side.
        VW wanted $250 for a new one!
        2018 Crafter Runner
        2012 T5.1 6sp manual.
        2024 Crafter Auto
          Thanks for that. Is there a particular method for the sliding door you would recommend?
          There are so many suggestions floating around.
            Keep the tracks clean, use teflon base spray lube and don’t put a lot on them. I use mainly Wurth product for it.
              I've been using silicon food grade...............seems to do OK.
              2018 Crafter Runner
              2024 Crafter Auto
                Thankyou for that. Wurth is certainly expensive. And they say they only sell to the trade.
                There is some product on ebay.
                Is this the correct one? - Wurth HHS Grease PTFE White Adhesive Lubricant Spray Can Silicone Free 400ml
                Thanks also. But in reading the forums, which in the end confused me, I thought the view was not to use grease or silicone on the sliding door? But I can't remember the reason for not using silicone?
                  Yes, it is. It’ll last you long time. Their cans hold pressure very well, even after 10 years.
                    The only thing I can think of not to use grease is maybe it will attract too much dust. I have been thinking of trying to inject some grease in the bearings on mine, after all that's how they were made. I have tried using Teflon spray, but it tends to wash out the original grease.
                    Re. the silicone grease, it maybe to stop getting it on the paintwork in the event of any future paint work. If anyone has worked in car manufacture, bringing any silicone product inside the factory is banned because of potential problems with paintwork.
                    Numerous Mk1 Golf diesels
                      Silicone spray is the biggest enemy of panel beater repair shops , if you want to cause a big reaction stop outside one and spray some into the air . If the prevailing wind is right you will have an angry mob after you .
