Our climate is not considered a wet climate compared with other countries like the UK where they sell lots of T5.1 & T6s.
T6 Underbody Plastic
Try telling that to those here in Qld and the northern part where yearly flooding rains would easily exceed what most of Europe would get and add in the fact at lot of our roads are substandard in comparison to most of Europe , drainage from roads creek crossings and loads of other factors would make driving through low level waters a common occurence .Originally posted by jets View PostOur climate is not considered a wet climate compared with other countries like the UK where they sell lots of T5.1 & T6s.
This is the point I was trying to make Sunny,"at most 25mm". I have seen lots of vision [SBS news] of flooding of various parts of Europe with cars being washed away, bobbing away in floodwaters.Originally posted by TonyMax View PostI was driving over highways with at most 25mm of water sheeting across it. I wasn't doing creek crossings.Understand how it works, troubleshoot logically BEFORE replacing parts.
Numerous Mk1 Golf diesels
Yes you are right Jets but lets not take away the fact that VW have made many blunders in relation to not recognising local conditions. Dont start me on the infamous Tiptronic n the early T5 and how easy it was for the fuild to burn due to our climate , once its lost its viscosity thats when you lose your auto .
When I bought my first T4 [approx. 03] that was an auto., I read all the faults by VW on not recommending changing the oil & filter &Originally posted by Sunny43.5 View PostDont start me on the infamous Tiptronic n the early T5 and how easy it was for the fuild to burn due to our climate , once its lost its viscosity thats when you lose your auto .
overheating trans. that owners are still re-engineering to make them last. Ref. Eurovans over on the Vortex forum.
What is disappointing is that the T5 seems to be exactly the same after over a decade of bad experiences with T4/ Eurovan.Understand how it works, troubleshoot logically BEFORE replacing parts.
Isn’t the T5’s 6sp tiptronic automatic transmission (Toyota baby) out our production for over 10year?
More on topic now. I service quite a few T5s and also owned T5 4motion for 11 years and was very happy with it, the best van ever.
Now, let’s not spoil the others T5 and T6 owners experience and don’t give the bad impression about quality.
To make that clear there is no more 6speed auto in the T6 and in the T5 from 2010 model year at least.
To all others who broken underbody plastic protectors.
The Volkswagen commercial vehicles have their own faults just like any other brand.
Though the plastic undershields are the best out there, here are the pictures of underfloor from the 2012 model driven by tradie electrician for 117,000km. They’re all intact and in perfect conditions. No flimsy plastic, but even the strong plastic can be broken if one drive in extreme situations. In which case you can’t blame it on manufacturer.
It all looks very solid under the T5 and I believe the T6 as well. Here are some pictures and I will post some from the T6 later on.
Please, don’t hesitate to post pictures of your broken underbody parts and for clarity pictures of the underbody floor as well.
Sent from my iPad using Tapatalk ProLast edited by Transporter; 16-02-2019, 04:48 PM.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
The only issue we ever had with under body protection on our early T5 was lack of protection of the diesel fuel cooler , again bad planning by VW for local conditions as on ours it was the ONLY place that wasn,t protected and was directly behind the passengers front wheel . That same wheel is first one to go off road during normal driving and as happened in our case a rock got thrown up directly into the cooler with resultant fuel spewing out onto the road , when we stopped at the next set of lights at night mind you we took off and found ourselves in the middle of the intersection facing the oppositte way as it had coated the road with diesel and we all know how slippery that stuff can be against rubber . Then on our nice new T5.1 VW decided to be as tight as a fishes ahole and didn,t even fit an under engine cover that all our previos three Transporters had as standard .
Most of Transporters I see have the engine under tray.
Agree with you on the fuel cooler, they could’ve put screen in front of it, though the airflow and cooling affect would be reduced. Again many don’t have any issue with it and on my 4motion I’ve never had an issue with it either. Of course you can be unlucky and small rock flung from the wheel can damage it as well it can damage anything unprotected under the van, incl. fuel tank, these things happen and I wouldn’t crucifie the manufacturer for that.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
So has anyone been able to find aftermarket underbody protection that is actually available and doesn’t cost the ridiculous prices of the German Seikel products?
I can assure you ours has no under engine cover like all our previous ones had and part of my point about local conditions may have been missed . In Europe they drive on the oppositte side of the road so chances of the fuel cooler being struck is almost impossible , in our country the left front wheel is the first one into the gravel at roads edge . Now I would never consider it a necessity to rejig the layout just for us but how hard would have it been to make suitable shield from perforated alloy to protect a vital part , sadly its again lack of recognizing local conditions due to lack of testing here .Originally posted by Transporter View PostMost of Transporters I see have the engine under tray.
I’m sure if it was common problem they would’ve address the issue. But, it’s not so just because couple of unlucky ones travelling on rough roads they won’t change the production. Simple like that.Originally posted by Sunny43.5 View PostI can assure you ours has no under engine cover like all our previous ones had and part of my point about local conditions may have been missed . In Europe they drive on the oppositte side of the road so chances of the fuel cooler being struck is almost impossible , in our country the left front wheel is the first one into the gravel at roads edge . Now I would never consider it a necessity to rejig the layout just for us but how hard would have it been to make suitable shield from perforated alloy to protect a vital part , sadly its again lack of recognizing local conditions due to lack of testing here .
You or anyone can call to spare parts and ask how many fuel coolers were sold.
Don’t be surprised if it’s not even in the stock.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
LOL!Originally posted by Sunny43.5 View PostYes you are probably right but when a simple rock cause over $800 damage you get a bit peed off that it happens so easily . lets leave it at that .
Speaking of rocks.........
Got a bullseye on the screen of my new Crafter in the first month!2018 Crafter Runner
2012 T5.1 6sp manual.
2024 Crafter Auto
