2010 Multivan Convenience Module
  • 2010 Multivan Convenience Module
    Hi All,
    So have a problem with my 2010 Multivan,
    Is showing multiple doors open and locks are locking and unlocking intermittent
    also today hazard lights started going off.
    Have done a few searches and everything I can see is says the module is under the drivers seat?
    only module I can find there is for towing. Also most parts places list the part as out of stock?
    can anyone confirm the location of the module in the 2010 models? And if anyone has had similar issues?
    Check under the passenger's seat instead. Unplug it and open it up to see if there's been any water ingress.
    The main reason there's nil stock is that it's probably been superceded to another part number.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      Thanks Mate,
      looked under the passenger seat already, no module there
        Drivers Seat, Towing Module on right
        Passengers Seat no module?
        Anyone know where I can find the convenience module?
        Steve
          In your first photo there are several connectors unplug them and check carefully for corrosion , our central locking was playing up on both of our 2 T5's when I unplugged the conector it had more greenery than an outback farm on those contacts . You can buy a contact cleaner and then a second product to improve the transfer of power through the pins . Easy way to check which one is the culprit is to discconect one at a time and see if the locks stop all together . Also check the remaing ones under the other seat as well , seems the T5's have an issue with moisture under the front seats .
            Wait, these have a BCM which I believe encompasses the convenience module.
            It's under the dash on the drivers side. You'll need to pull the bottom half of the dash off to get at it.
            '01 Beetle 2.0
              I thought was rid of the temperamental sliding door locks when I sold my 08 multi for a ‘12 model but no, same issue with new van, interesting the door would unlock if child lock is on �� right door works fine but left won’t open when cold, in the mornings
                Umai I had to google bcm, too many acronyms in the English language for me to remember, so is there a control module concerning the door locks under dash that anyone had succes with in fixing unlock by remote issues?
