T4 Immobilizer code on OBD
  • T4 Immobilizer code on OBD
    Hi guys, a couple weeks ago the T4 decided to not fire, so i got a mate around to plug the OBD in and voila (see attached)
    Wondering if anyone knows where to go from here? Easy fixes? He seems to think its a send away for reprogramming job.
    appreciate any insights.
    Did you try Mr Google, here's one.
    17978/P1570/005488 - Ross-Tech Wiki
    Numerous Mk1 Golf diesels
      Clear the codes, and make sure the MAF is plugged back in.
      I assume it's a petrol? It's probably a dead coil, or the ECU relay has crapped out.
        Could be a problem with the key as there is a immobiliser built into the point where the key is plugged in , it reads a code from the key and it its not sending it wont start . Have you got a second spare key try that , the relay mentioned is a BCM relay and they DO fail , mine stopped the van almost mid intersection .
