Help Identifying T5 Transporter Part
It's the handbrake tensioner , I crawled under ours and if you look forwards from the rear you will see the two cables going to each rear wheel . If you look on the cross member the spring attaches to the body and then onto the part that the two cables are retained on . I will post a photo shortly .
Originally posted by Sunny43.5 View PostIt's the handbrake tensioner , I crawled under ours and if you look forwards from the rear you will see the two cables going to each rear wheel . If you look on the cross member the spring attaches to the body and then onto the part that the two cables are retained on . I will post a photo shortly .
[ATTACH=CONFIG]33306[/ATTACH]
[ATTACH=CONFIG]33307[/ATTACH]
No Problem it never hurts to ask a question regardless of how strange it may be .I put the part number into a Google search like this 701711367VW and it gives quite a few places that stock the part , now I would suggest checking local VW dealer first as a few places I looked at want around $40 to $50 for freight alone !! Small items are unfortunatley expensive to send it seems , I buy a lot of parts from overseas and even though they can be up to half the cost of local suppliers the freight has to factored in before purchase .Last edited by Sunny43.5; 25-02-2018, 03:14 PM.
