Originally posted by golfworx
View Post
This will include:
Bump stability.
Braking stability and performance.
Entry grip on/off brakes/throttle, high and low speed.
Midcorner grip and stability on/off throttle aswell as midpoint balance control.
Exit corner grip. I'm hoping for an improvement in power exit understeer due to a lower centre on gravity.
And i'm guessing the shocks are stiffer, probably with more rebound resistance, which would also improve the power understeer issue.
All that said, i'd say that the van should have more grip all round, because i'm guessing the shocks are more handling oriented and less of a ride/handling compromise. Also, if you haven't noticed, the front springs are rising rate.
