anyone know what colour the high beam wire is on a 2009 vw caddy?
high beam wire colour
Tags: None
2 years on, does any body know?
You really need to supply more info.
Where are you looking? Engine bay back of headlights? Under dash? At fuse box?\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
sorryOriginally posted by Gigitt View PostYou really need to supply more info.
at the back of the headlights would be the easiest spot i think.
TIA
Now what I would do is:
1- open us the covers behind the headlights just like you are going to change the globe
2- find the 2 wires going from the high beam globe and trace then back to the inside part of the rear headlight connector
3- match the wires to the headlight harness. One will be earth (brown wire?) and the other coloured wire is you high beam.
In my mk5 Jetta there are 4 thick wires. The others are thinner. 4 thick wires = 2 pairs for, low and high beam.
Or you can use a multimeter. But I wanted you to read it all
High beam is always white(brightest),yellow(not as bright)parkers are grey(not bright at all)Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
