2011 Caddy Air conditioning not cold enough
  • 2011 Caddy Air conditioning not cold enough
    Hey,
    Ive had my caddy now for about 4 years and have found the air conditioning to never be crisp cold. In the past ive checked and replaced the cabin filter which helped a bit, checked and cleaned the condenser coil etc. Ive had enough and want it working like the rest of the cars around here so i checked a few more things. The condenser find near the bottom do seem bent but because of the style of the fins, i cant use a fin comb. even trying witha small screwdriver just cant really straighten it. Ive noted on idle it feels like it only cools a bit but if i run the engine at 2000rpm on standstill it is notably better. Condenser fans are both running. Im doubting a gas leak as its been fairly much like this last 4 years, but who knows what service was done previously. The Previous owner had it serviced by VW as it was still under warranty, and i purchased the vehicle with 55000Km.
    Ive run it through VCDS and have the results below. as its basic knovbs and not climate control i noted the footwell and centre temp sensors all say 0.0, but the interior temp sensor comes back with 27 deg regardless of the real temp, noted that on other days. the evap temp eventually gets to 17 deg at idle and goes 13-14 deg on 2000rpm. The manual says the temp out of the vents should be 7 deg or lower.
    Any suggestions?
    AutoScan results:
    Saturday,28,November,2020,13:01:42:08461
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.4.2.0 (x64)
    Data version: 20200730 DS317.0
    www.Ross-Tech.com
    VIN: WV1ZZZ2KZBX245397 License Plate:
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WV1ZZZ2KZBX245397 Mileage: 166840km-103669miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 1110
    HVAC Module, no errors.
    When at idle
    STAMP
    88.65​
    Coolant temperature
    37​
    Refrigerant pressure-MUX Kaeltemitteldruck
    11​
    Compressor shut-off requirement Compressor active: no shut-off condition is present
    Compressor current: specified value
    0.82​
    Compressor load
    5.6​
    Coolant fan activation: actual value-MUX Lueftersteuerung
    36​
    Outside air temperature-MUX Temperatur
    40​
    Outside air temperature internally calculated-MUX Temperatur
    40​
    Temperature after evaporator-MUX Temperatur nach Verdampfer
    28.7​
    Interior temperature
    27​
    When Accelerating
    STAMP
    266.52​
    Coolant temperature
    54​
    13.6​
    0.82​
    Compressor load
    7.5​
    49.6​
    40​
    40​
    17​
    27​
    And again accelerating
    STAMP
    372.53​
    Coolant temperature
    60​
    15.4​
    0.82​
    Compressor load
    2.6​
    60.4​
    40​
    40​
    14​
    27​
    When idle again
    STAMP
    518.12​
    Coolant temperature
    69​
    13.6​
    0.82​
    Compressor load
    7.6​
    52.4​
    40​
    40​
    17.3​
    27​
    Mick K
    __________________________
    2011 VW Caddy 1.6 TDI
    2004 VW Touareg V10 TDI
    1989 VW T3 Transporter
    1984 VW T3 Transporter
