Hi all,
Okay I am at my wits end I do not know what to do next. The problem car is a 98 6n1 auto which only had a heater when you are driving over say 3-4k rpm, let it come back to idle and it just starts to blow cool again.
Things I have done so far
1) flushed heater matrix (it is/was clear and does not appear to have any blockages) and changed unit for good measure.
2) removed heater box and repaired mixer flap (the foam had all come off) (not a job for the faint hearted, its a PITA!
3) changed thermostat
4) removed and inspected water pump. It had previously been changed (not by me) and now has a brass impeller version as opposed to the plastic ones normally in these cars
5) flushed entire system with pressure cooling thing that you vac down then inject coolant into
6) flushed radiator (no blockages)
and yet it still does the same thing.... what have i missed? How is the water pushed through the heater matrix? It looks like the inlet and return pipe from the matrix are just connected to the coolant regulator housing so what actually pushes the water 'through' it as from what i can see there is little to force the coolant through.
What have a I missed????? I'm just so confused.
