Blocked breather on 6n2 AHW
  • Blocked breather on 6n2 AHW
    I had our Polo on a friends hoist to change the fuel filter & noticed an oil leak on the rear of the engine. I figured it needed a new seal.
    This is a pic of the breather box after a cleanup & removal of the bracket that supports the cable to the starter.
    After removal of box[three screws with 5mm allen key] I found the hose & box completely blocked with oil mixed with water, sometimes referred to as mayonnaise.
    I bought a new hose assy for just over $100 that includes the heating element that was no longer working. I believe it is there for cold climates to stop iceing & blocking the breathing. The rubber hose had gone very soft & when squeezed stayed distorted.
    Numerous Mk1 Golf diesels
    Hi Jets,
    About to do this myself, so if you don't mind me asking mate, I can do this job with jack stands and a 5mm allen key?
    I replaced the breather pipe a month ago which was completely stuffed and cracked, and I reckon there is heaps of gunk in the breather case, so I have a new one ready to swap over.
    Any assistance would be appreciated.
    Thanks.
    Micky
      Originally posted by Micky View Post
      Hi Jets,
      Thanks.
      Micky
      Yes you can without issue, it's not 'hard' you just need to feel the top bolt as you won't be able to see it, but yeah.... Not difficult
      My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
      If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
        Just spotted your post. From the date on my post some time has passed since I did mine.[no longer have our Polo]
        I did mine on the floor & from memory an easy job.
          Hi Guys, Thanks for the follow-up, I will give it a crack on the weekend!
          -------------------- UPDATE -----------------
          Ok, so this weekend I replaced the oil separator on my 6N2 Polo with AHW engine.
          As mentioned from the guys here, the job (once you tackle it properly) is not that hard, but I will say it is tedious, more so take off the very top 5mm allen bolt. As mentioned by Jets the bracket that supports the starter cabling needs to be removed, this is quite easily done with a 13mm socket wrench or ratchet.
          I didn't get to do much pics of the install but as mentioned all you need is:
          5mm allen key (3 x 5mm allen bolts to remove)
          5mm stubby allen connected to an extension (purely to remove the rest of the bolt after loosened and reinstall as much as possible, by hand)
          13mm socket with ratchet (1x 13mm bolt to be removed, supporting bracket)
          From there it is quite easy... I must mention I did this job using jack stands and lying on my back to do the removal and installation, no the most comfortable, but only option I had.
          If you are using jack stands and laying on your back, it is best to take the 2 lowest allen bolts with your right hand coming from the side, and then your left hand to go for the top allen bolt, (you won't see the top bolt or have access to it if you don't remove the bracket as mentioned)
          Again sorry not enough pictures, as I am mostly adding pics for the "shock factor" of what the oil separator was like
          Similar pic to Jets here from his original post.
          After some hacksaw work this was found inside!!!
          Totally disgusting, is what found inside that is for sure, and if anyone is doing this job, I do not suggest to try and clean it out, just buy a new oil separator and breather hose if you have not already.
          Now for part numbers (remember this Polo is a 6N2 model 1.4L / Engine: AHW / Power 55kW) as I believe this is the only engine type that ever entered Australia)
          Oil separator:
          Original VW part: 036 103 464 G
          Aftermarket FEBI part: 38773 (I used this part and purchased from amazon.de, remember 20% vat is taken off price for Aussies )
          Breather hose:
          Original VW part: 036 103 493 BB
          Aftermarket YILDIZ HORTUM part: 14408 (I used this part and purchased from turbohortum.com (23 Euro all up and expressed in 3 days!) ,mine however does not have the heater element, just the hose one piece, please check your model, as it may have the heater element!) - (The hose itself is quite thick and firm, probably better than the original VAG part in my opinion, however will see how it goes in a year)
          When re-installing the oil separator, make sure to install the breather hose again to it (in it's correct position to connect to the air filter box!), if the new one is quite tight (which I imagine it would), just put the hose in some hot water for a minute or two and try to get rid of any water inside and then it will easily connect/slide onto the plastic hose connector from the oil separator.
          I think anyone who has a 6N2 should look into this, as it is a common problem and should be looked at asap, and if necessary changed!
            Thanks for the update Micky. It's detail & pictures like yours that help others on this forum. Well done.
              mmmmm looks like mayo.
              Is your engine using any water? ive had one apart before too and it was nothing like that, it was black firm carbon, not that sort of consistency.
              Just curious.
                Just curious.
                Hi Pontiff,
                As I only got this car around 2 months ago, silly me never noticed the huge crack in the original breather hose, as it was on the underside which I could not see, so I imagined as it was like this for a while, that there was a lot of moisture entering inside and causing it to mix with the oil and cause this (mayo), I checked the top of the hose today and looked in the air box, still clean as a whistle, so again the neglect of this bad hose (originally fitted) that was cracked was the culprit of this mayo.
                Oil levels have also been good.
                Thanks for your nice words jets!
                Now I have a bit of play with the clutch pedal and I am hoping it is not the pedal box, otherwise I am in for some fun!
                  Just wanted to reply as an update:
                  Almost a year after I did this job and all is well, motor is doing fine and going strong as ever...that a 1.4 can do
                  Breather hose (aftermarket) purchased for this job looks in excellent condition and no sign of mayo at all in the hose after placing a rod with some cloth at one end as far as I can shove it down.
                  I will need to post some pics when I get around to it.
                    Thanks for the update with positive results.
                      Update after 3yrs:
                      Replaced a gear linkage today, result means cannot go into 1,2, 5 and reverse. Easy fix. Might do a write up soon.
                      As I was doing this, noticed the hose has cracked bad on the bottom, so for this in future, I recommend to go OEM! Will call VW on Monday for original breather hose.
                      Go Tiges!!!!
                        Update after 3 yrs from previous 2019 update:
                        Hose is still fine, and removed breather box while doing some other work on car, and is still clean, as mentioned stick with OEM when ever dealing with the breather pipe.
                        Not seeing much 6N2 these days on the road, I do look after mine a lot though (216000km so far)
                          Update after 3 yrs from previous 2022 update:
                          Breather hose is still good and box, no mayo or condensation can be seen, but car was out of action for 2.5 yrs! and rebuilt gearbox cause the input shaft bearing **** itself (October 2022) so had to put on a new shim and bearing, cleaned all inside and out of gearbox and put some nice liqui moly 75W-90 in it.
                          Surprisingly after the gearbox made an explosion sound when it did **** itself, the gears were still in ok shape.
                          Now the car probably drives better and smoother than when I purchased it in 2016.
                          Other parts and bits done at same time when gear box installed:
                          New Fuel filter (BOSCH: 0450905316)
                          New front wheel bearings L + R (FEBI: 19912)
                          New back seat rubber pullers (to put seats down), cause old ones snapped lol
                          Window switch, cheap buy from Aliexpress
                          Emptied fuel tank completely before initial start and added liqui moly fuel cleaner with 10L U91 fuel (biggest prick is reinstalling fuel filter, rather do the gear box!)
                          New spark plugs x4 (NGK: 15-BKUR6ET-10)
                          New starter motor, well reconditioned (LUCAS: LRS00892)
                          Oil change: Castrol edge full synthetic 5w-30 + liqui moly MOS2 friction remover (yes the stuff works!)
                          Oil filter: (Bosch: 045110331)
                          Clean throttle body
                          Clean MAF sensor
                          Clean and recoat BMC air filter
                          Bosch aerotwin wipers and new rear wiper, ready for winter
                          Pics for fun:
ID:	1861940Click image for larger version
ID:	1861941Click image for larger version
ID:	1861942Click image for larger version
ID:	1861943Click image for larger version
                          The car is still fun to drive and I won't give up on it yet!
