How much Bar of boost is in a Polo GTI ?
  • How much Bar of boost is in a Polo GTI ?
    How much Bar of boost it stock running on?
    How much Bar of Boost with APR Tuned running on?
    Stock is like .9bar or 1bar from memory?
    My APR has seen 1.5bar some nights.
      I have APR now. but i was just wondering how much boost its packing
        8-10psi (0.55-0.7bar) stock and 14.5psi (1.0bar) APR - I think that's right anyway
          stock peaks to .82 bar then drops to .55 bar or 12 & 8psi
          tested last week with a vdo boost gauge.
          - 08' Polo Gti, White - APR v2 - Milltek CatBack - RE 001's -
            Maybe i have no idea.
            Or my cars stuffed?
            Where are you nubs running the vac lines from by the way?
              Or my cars ****ed?
              Someone has mentioned in another thread that APR boost peaks or spikes up to 22psi. I remember this because I was going to buy a boost gauge that gave a reading up to 20 psi and then found out the GTI goes beyond that.
              So Kai your figures are not wrong and your car is not f***ed unless your car and the other guys car are both f***ed.
                Originally posted by http://www.goapr.com.au/products/ecu_upgrade_polo18t.html
                The software for the GTI is available in a 1.0 bar configuration and 204 horsepower (152Kw) and 242 ft. lbs (328Nm) of torque
                I'd say that would be a pretty good indication of what boost the APR tune is set to (excluding spikes)...
                  Get some sort of boost gauge and then tell everyone its running only 1 bar
                    Ok..This info i got off the guys at APR...Stock boost peaks at 7psi(about 0.5 BAR), and APR tuned boost peaks at 15 to 17 PSI(about 1.1 to 1.3 BAR).
                      I run a boost gauge and boost normally peaks at 1.3 bar before eventually settling at 0.9 bar. Diffferent fuel have seen peaks of 1.5 bar !
                        1.3 bar seems like pushing your luck if reliability is concerned? My stock Polo GTi peaks .91 at 3K rpm and settling down .5 - .6 onwards
                          KO3S turbo fitted to our cars can take up to 20-22 PSI (1.6 bar or there abouts). Talk to APR or GIAC or REVO if you have any real concerns. They are all very helpful.
                            33psi, spikes to 36psi....
                            Oh, thats stage 3+ with a GT2871R sorry
                              the boost gauge my mate bought off ebay must be so cheap cuz it was only showing 15 - 16psi wit apr
