OBD port
  • #16
    Yes it's a 6 speed auto
    No it's not a GTI
    However it does have GTI suspension fitted (hence the reference to GTI)
    And I'd say FLOODY is right on the money with that point, hell I give him **** for it but that's between mates.
    • #17
      Ahhhh, it makes sense now. It's the auto display. Sorry if it seemed like I was having a go at him, I've never been in an auto Polo and didn't think of it.
      • #18
        No it's not a GTI
        I understand it's got GTI suspension, but adding GTI to his sig is a bit much just my opinion.
        aus liebe zum automobil
        • #19
          LOL Ahhh yes...
          • #20
            This thread has seriously deviated too much. When did this become an open discussion about my car and what I have in my signature. People GET OVER IT!
            GTI|BBS|Forge|Whiteline|Custom CAI+K&N|Sparco|Toyo|Martini|JVC|Focal|ScanGaugeII
            • #21
              Well I'm sorry but adding GTI to your sig because you got GTI suspension ??? what you thought that was the done thing? You put it there so accept the criticism.
              The lap timing software I use (RaceChrono) for the track has included an OBD-II feature. It uses data from a Bluetooth OBD-II dongle, http://www.obdkey.com/ This can be used for lots of other applications.
              It can record RPM, Throttle position, coolant temps, airflow rates & of course speed. It will graph these along with the GPS speed so for example you can see the RPM for each corner.
              • #22
                What I do is my own freedom and choice. Furthermore, has it not occured to the lot of you people that in my signature it has '1.6L'. When did a 9N3 GTI exist in a 1.6L configuration? Build a bridge and get over it
                • #23
                  Hey,
                  The 1.6 6spd auto polo in fact goes well 2....
                  And the engine sound is great too, it will change voice on the upper end!
                  I driven one of those as a coutesy car from the dealer...
                  • #24
                    You're spot on there! The engine does sound very nice, especially with a CAI (ask Jon as he's driven it). It starts to bark as soon as it hits 3500rpm's, and get deeper as it progresses up the rpm's.
                    Hopefully you got to drive it like you stole it
                    • #25
                      Is that because you don't want to tell anyone you bought it?
                      • #26
                        General consensus of loan vehicles are that people behind the wheel of them most likely drive them like they're stolen However, there are some sedate drivers behind the wheels of loan vehicles at times.
                        • #27
                          Got a greddy one from the net, plug it in and it doesnt work...
                          It said ecu communication error...
                          Hmm....
                          And the plug seems not fitting as well... I need to push it with force, and even i pushed it in, it feels a bit lose...
                          What is going wrong? Did i plug it in at the right place?
                          • #28
                            There's only one ODB port - its located under the litte undertray: above the pedal.
                            Its a shame that the Greddy ones doesnt work, but eBay is your friend
                            • #29
                              The one with the purple plug?
                              Hmm...
                              I tried to plug it in this morning, and i have looked at it again and found that the obd port is rectangular, does it mean the plug can plug in 2 direction?
                              I will try to plug it in up side down and see how it goes...
                              Celestine, is urs able to plug in with another direction?
                              • #30
                                ^should have a cover on the plug "OBDII"
                                and yes like what "celestine" said, scangauge II is awesome, had them when i used to drive the Toyota Echo, so accurate as well, and also tells you how many horsepower/kilowatt your car is producing in real time
                                best of all, you can use it up to 10 different cars and all the settings will get stored into the scangauge memory.
