Originally posted by hkogti
View Post
Gauage pod for polo
I havnt done anything yet, but thinking making an insert for the middle part out of fabre glass...Originally posted by hkogti View Postsj88, how d wiring goes with your gauages? Just drill holes on the top tray? Did you do that yourself or fitted by a mechanic? If so, which? It looks pretty good! I am thinking to get oil temp and boost...
Thanks mate - yes I appreciate the top cubby is the more ideal place to mount a boost gauge but as apready mentioned above it'll also make it very vulnerable to theft (that's not to say thieves can't still steal the gauges and take the radio with them if they really want to if I mount them in the 2DIN hole).Originally posted by Celestine View PostAre you purchasing the staggered three pod configuration or the flat three pod configuration? The staggered doesnt fit flush as the staggered sections physically stick out of the 'din', where as the flat ones will sit more flush.
The reason I say more is - they are still Japanese sized single dins, and the Euro single din size is about 2~3mm's larger each side compared to the Japanese din. Furthermore, you need to remake the mount as mounts that come on them wont hold the weight of the gauges in the Polo's dash and figure out how to fill in the sides.
Just several things to consider before you dive into the project.
I've now bought a cheap cubby to fill the upper DIN space, to be replaced by boost/oil pressure gauges at a later stage - yes unfortunately they will be out of line of sight but I'm thinking about buying a lidded cubby to hide a GPS unit at yet another stage and mount it so that I can simply flip the lid open to reveal the GPS, besides the gauges only need a cursory glance)
The cubby box probably wont be able to accommodate for most GPS's as the clearence isnt very good. I'm halfway through making a double gauge cluster for where the centre upper cubby box is. I'll post pictures once I'm done.GTI|BBS|Forge|Whiteline|Custom CAI+K&N|Sparco|Toyo|Martini|JVC|Focal|ScanGaugeII
Thanx for the site man...Originally posted by Roodosutaa View PostBTW this is the only column pod I know of in existence for the Polo:
But at over $200 delivered (AUD to yen is about 1 to 100 and I'll bet shipping isn't going to be cheap either) you'd have to have money burning a hole in your pocket to go for this.
It looks too glossy so chances are it will be a mis-match, ....seems to obstruct vision to the dash cluster also, mostly the tacho.Originally posted by Roodosutaa View PostBut at over $200 delivered (AUD to yen is about 1 to 100 and I'll bet shipping isn't going to be cheap either) you'd have to have money burning a hole in your pocket to go for this.
if the product was good quality Id be interested in taking them on in QTY to put together a boost gauge kit for Polos. I wish i had a dollar for every enquiry ive had. Hopefully it takes off
FOLLOW US ON FACEBOOK
Yeah I will later on tonight. I might send the instigator a message to see what his thoughts are and what sort of quanties they need to do a production run.
Im thinking it will take lot more than 10 pieces to get it off the ground. Surely they would need to produce them in volume to make it worthwhile.
Alternatively if anyone knows someone who can produce/develop the vent piece locally that may be worth looking into as well. Putting together a gauge kit after that shouldnt be very hard at all. I can certainly see there would be demand for an affordable product worldwideLast edited by Tim; 30-10-2008, 02:40 PM.
I think it looks OK. Somebody should bring some in.
I am wary of the routing of the boost line though. I had some trouble routing mine to the top of the dash using the left engine bay access. I have no idea on how to get it to the drivers side and am wary of what will be requied to do so.
We need a test dummy to do a full instruction write up ....
Last edited by Sharkie; 03-01-2009, 05:10 AM.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
