The other day I decided to investigate why there was so much movement in the gear shift
I firstly pushed up the surrounding plastic trim, then pushed the the shift boot upwards out of the trim by undoing the clips ( I broke two)
I then discovered a broken spring which can be seen below (the centering spring)
this pulls the gear stick back to center and applies spring force in all gears
I then compared to a polo club which is how the spring should look
I sourced the spring from a vw dealer today and cant seem to work out how to change it.
I am thinking I will need to drop the linkage box which would mean removing the exhaust
does anyone have any experience on replacing this?
Thanks
Thanks
