After some advice on starting/cold pressures for:
1: advan AD08R standard size and
2: bridgestone RE003,
This is for hillclimbing where there is zero opportunity to get heat into the tyres and the total run goes for 1min. ie I need stone cold grip by the first (20metres away) corner.
I know that on the track you might set the yoko's somewhere around 30psi and the street tyres around 35psi but I'm pretty sure that won't hold true when I can't get a pressure change into them. Even if each was set optimally for what I'm doing, I'm actually wondering if the RE003's might go better than the yoko's in terms of giving instant cold grip
thoughts!
thoughts!
