Hi poger's! My 2007 gti has a P0116 code which has come up a few times now; seems it's every few weeks, and usually when I'm driving sedately.
I've replaced the ECT sensor as a matter of course, but it's just come back. Apparently the other common causes are old and rusty coolant, or dodgy wiring/connections. My coolant generally seems in reasonable condition, so was just wondering if anyone has had this problem and can suggest where on the wiring to look for issues?
Also, I've reset the fault code, just just wondering if anyone knows if there's a finite limit to how many times you can clear fault codes on the Polo ECU? I know some ECU's need to be factory reset after a certain number of fault clearances.
Any help greatly appreciated!!
Cheers, Steve
Cheers, Steve
