Im just curious for anyone that has the APR reflash what program is stock and what program is flashed? ie blink one (program one) blink two (program two).
APR ECU Programs
Originally posted by mitch_gti View Postpretty sure the double flash is the APR power setting.
in saying this however, it can be installed the other way around. i'm sure if you have a fiddle around for a couple of minutes, you will know the difference!
Thanks guys. My chipped mode is Program two.
My car is definately playing up, it hasnt go the normal kick it used to have. Im missing a fair amount of power. I will check for any boost leaks etc.Current - MY12 MK6 GTI, CW, Detriots, dark tint, APR Stage 1, blacked out grille, LED tails, Euro plates, suspension "tweaked", VCDS tweaks
"The Ex" Black MY08 POLO GTI - APR,Coilovers,5% tint,stubby antenna, rear sway bar
Mate, either you're getting used to it (....it happens....) or could also be a bad batch of petrol.
I've noticed (since I added a boost gauge) that different fuels actually vary the max amount of boost (3rd gear) I'm getting.
Not wanting to start with an old thread again, but BP Ulitmate holds at 1.3 bar, V-Power at 1.4 bar and V-Power racing at 1.5bar. Never would have guessed untill I happended to switch due to necessity and saw a drop in boost. Not any real drop in noticable power though.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
Originally posted by [-Polo GTI-] View Postspot on mitch. single flash is standard setting and double flash is race-gas setting (chipped). you then need to turn your car completely off for 10 seconds before firing up.
in saying this however, it can be installed the other way around. i'm sure if you have a fiddle around for a couple of minutes, you will know the difference!FOR SALE
"VW GTI" QLD Prestige Plate
Well I know its missing a beat and im not getting used to it.
I thought it was petrol because i normally put in BP Ultimate but couldnt find any stations that had any type of 98 RON so I had to put in $15 of Mobil 95 RON, then I filled up with Caltex Vortex 98 and it was still running **** then I just filled up with BP Ultimate 100kms ago and its still running poor.
I thought if it was the petrol then it would be coming good by now.
Originally posted by Sharkie View PostMate, either you're getting used to it (....it happens....) or could also be a bad batch of petrol.
Not wanting to start with an old thread again, but BP Ulitmate holds at 1.3 bar, V-Power at 1.4 bar and V-Power racing at 1.5bar. Never would have guessed untill I happended to switch due to necessity and saw a drop in boost. Not any real drop in noticable power though.Current - MY12 MK6 GTI, CW, Detriots, dark tint, APR Stage 1, blacked out grille, LED tails, Euro plates, suspension "tweaked", VCDS tweaks
Get it onto vag com and do a scan for codes. I know mine is different but still the same in this aspect. I was throwing a code for air/fuel ratio. Cleared the code and the car was back to it's screaming old self but not for long. A quick hunt around and I soon found I had a boost leak from my intercooler intake pipe. Tigten up the clamp and off she went after clearing the code again never to be seen again.Originally posted by WhubbsieThere is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
Yeah ill have to check it on VAGCOM and see if it throws any codes.Current - MY12 MK6 GTI, CW, Detriots, dark tint, APR Stage 1, blacked out grille, LED tails, Euro plates, suspension "tweaked", VCDS tweaks
Should have finished my post.....
Bad batch I was talking about happened to be V-Power, and was off by at least .2bar for the whole tank. I also thought something was wrong.
Only sorted itself out after running a full tank of BP Ultimate and then a full tank of V-Power again.
Filling up with V-Power Racing later today........
There's nothing like a boost guage (actually quite easy to fit) to show what the car is doing and should point to a boost leak very quickly if power drops persist.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
Originally posted by Flaps View PostHey Koz I think I spotted your car outside Kellyville shops this morning about 10.30am. It had plates starting wtih KOZ ### so I took a wild guess. Looks goodCurrent - MY12 MK6 GTI, CW, Detriots, dark tint, APR Stage 1, blacked out grille, LED tails, Euro plates, suspension "tweaked", VCDS tweaks
I think I know why my car is running ****! Our cars are meant to be filled up with 95 RON or 98 RON - I was bone dry and couldnt find any premium petrol at two petrol stations so I had to put in a small amount of Regular Unleaded ($15).
I actually thought I put in 95 RON but now I remember it was reg unleaded.
Im sure this has contributed to the car running very poor.Current - MY12 MK6 GTI, CW, Detriots, dark tint, APR Stage 1, blacked out grille, LED tails, Euro plates, suspension "tweaked", VCDS tweaks
