Hey, so I have an with my 10' Polo 9N3 issue; My pedal is way too soft and it isn't as sensitive from factory.
Now, the issue arised when I changed my front pads, they were very low and the disc had a big lip on it.
I changed the passenger side and pressed the brake to push the piston out, I then did the same for the drivers side although now the pedal was soft.
I bled the front callipers, where performance improved a little.
I then changed the rotors two weeks down the track, as they were causing a squeak.
After that I thought to myself it's time to get to the bottom of this soft pedal.
I've bled the conventional way (furthest from M/C), the workshop manual way (PF, DF, PR, DR)
and in random orders to no avail.
When bleeding I have monitored the clear hose while my assistant depresses the pedal about five times and no air has come out.
After scrounging the internet I have read I may need to cycle the ABS or use a vacuum bleeder, two things I have no idea how to do.
My question now is, am I doing something wrong?
Any advice is greatly appreciated and you have my thanks in advance.
