Is that sway bar hitting on subframe? I know the position on the second picture, but can't tell what exactly your referring to with it. Sway bar links??
Suspension Knock / Rattle Turning at low speed
Daily: 2010 VW Jetta Highline
2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
Sway bar links... I have replaced mine several times now due to this noise. Berry a brand new set and put them in to see if the noise goes away. I have replaces strut top bearings thinking it was the noise you are describing only to have it be the sway bar links... Replace these before ou outlay the money for strut top bushes, trust me!!
Heh, funny asOriginally posted by VWindahouse View PostGuys found my culprit today
On the same topic, look at this, there is a video explaining it
Volkswagen Golf VI 2.0T Suspension Subframe ES#421475 Subframe Spacer Plate - Priced Each - 7M3499349A2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
Wow, Alex Turner from The Arctic Monkeys works at ECS?Originally posted by Martin View PostHeh, funny as
Volkswagen Golf VI 2.0T Suspension Subframe ES#421475 Subframe Spacer Plate - Priced Each - 7M3499349Asigpic
Mate photo 1. shows the witness mark from the tie rod hitting the sway bar after full lock.Originally posted by noone View PostNot sure what I'm looking at. Is the drop link oily looking?
Photo 2. witness mark on the tie rod itself.
Photo 3. tie rod actually hitting the swaybar at full lock.
I've got gopro's, what are you thinking and I can try replicate.Track Car: 06 Polo GTI Red Devil mkII
Was thinking of securely mounting it under the car near the front wheel and trying to replicate the problem, would give more of an indication as to where the sound is coming from, ecs have a few vids like this
2016 Golf R, APR Stage 1
Removed the Ultra Racing Strut bar and replaced the original strut bolts, got a feeling its the bolts or the bar, either way I'll give it a week and see how it goes, if no rattles i'll replace the bolts used on the bar with longer factory style bolts, this may be the remedy.2016 Golf R, APR Stage 1
After removing the strut bar, the issue is definitely better, only managed to make it occur on extra bumpy surfaces, possibly still an issue with the strut top but I think this has nailed the issue..
Will organize some bolts and see if it goes away with the bar in, if not the extra torsion may be the issue..2016 Golf R, APR Stage 1
My knocking occured before the strut brace went on, though in the last few months I've been driving the car daily and haven't noticed the clunking any more.Originally posted by flat6 View PostAfter removing the strut bar, the issue is definitely better, only managed to make it occur on extra bumpy surfaces, possibly still an issue with the strut top but I think this has nailed the issue..
Will organize some bolts and see if it goes away with the bar in, if not the extra torsion may be the issue..Track Car: 06 Polo GTI Red Devil mkII
Think around 50,000k's you start to hear a whole heap of new noises in the car, nothing major, just gets you wondering..
But I think this suspension knock is possibly a minor design bug with the car..2016 Golf R, APR Stage 1
