May be cheaper to get a s3 K04 - i got quoted 450, if you are going hybrid k03, you may as well go all the way on the turbo (same price as a mild hybrid),then port the turbine housing and exhaust mani, and that should get around 310-330, check out Badger 5 in the uk
An S3 K04 is a different beast to the K03s and would require a change of downpipe to suit it. So an additional cost and no off the shelf downpipes that I have heard of.
Right you are gav, Assuming you want to go the easy route and buy a miltek system (given you are in the uk) , S3 turbo and the Frankenturbo right angle downpipe adapter may work.
But considering you are in the uk , there are a bunch of turbo companies that hiflow and have gotten results., CH, badger would be good to use. and overall easier/better solution although it may be a bit more expensive.. even frankenturbo?
