Boat mode
  • Boat mode
    Ok guys, I'm after opinions on a new concern of mine.
    Was driving home last night and took a left hand slip lane at normal speed and the gti understeered like a royal pig and then the rear end went all wobbly thereafter.
    Took some more lefty's and the problem was still there. The right handers seem to be 'less bad' but still not confidence inspiring. Currently on a set of AP coilovers that Noone used to run, so I can only assume they're 2-4 years old. The rears are maxed out and the fronts still have room to go lower. I've checked all tyre pressures and wheel bolts and all appears normal. Short of having a late night feel of the rear shocks for weeping I can't put my finger on it just yet.
    My concerns are possibly a rear bush of some sort has gone, but other than that I'm stumped.
    Worth noting, I picked up a mate last night and when she was in the passenger seat - problem gone.
    Yes, it's one of the lowest static Polo's getting around at the moment, but bear in mind it's had the same setup for over a year now, so I don't care to hear about how my control arms are pointing upwards blah blah, it's been perfectly drivable for a long time now.
    Oh aye!
    I'd say the lowest static Polo in Aus from what I've seen...until I'm on 16's again
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
      Originally posted by nightphotographer View Post
      Oh aye!
      Bahahahahaha, you two crack me up.
      GIAC | FORGE | D2 | TURBOSMART | K&N | XFORCE |
        I'd start with the front tyres. Tyre pressure, balding, etc. May as well check the rears. I found higher pressure in the front was better, quite low in the rear (32), but the Kumho's were a soft sidewall with wide tread and hardened prematurely.
          Hmmmm, my Hancooks would be 1,500kms max at the moment. I'd really like to think they haven't worn out already, they're brand spankers! They're a 195/45/16 over an 8" wide wheel so there's a moderate amount of stretch in the equation, but I'm sure this isn't the issue as they used to grip fine before.
            you mentioned, "Worth noting, I picked up a mate last night and when she was in the passenger seat - problem gone."
            So get her weight, and put some bricks in -- you will kill 2 birds:
            1. no more boat
            2. even lower car
            Polo 9n3 GTI
              2016 MY17 Polo GTI with DA package. TMD fitted + Weather strip and Snow Screen removed otherwise dead standard.
                Originally posted by sssstew View Post
                HAHAHA I love how everyone has been distracted by one small detail lol. Anyone have any more technical advice?
                  tell her to go on a diet, she clearly changes the suspension too much!
                  09 Polo GTi "Elke" | APR DV1 | H&R 35mm | Bilstein B8 | Remsa Pads | Pioneer |
                    Things suddenly going all squishy is very rarely a case of something apparent have changed. A leaking shock is not going to do anything suddenly and the kind of internal failure that would (eg blown comp / rebound valve) usually only happens under shock loads
                    I'm afraid the only way to tell is to jack her up and slide under. I'd be suspect of the bushes as continual geometric abuse (yes lowering does have some very bad effects) could have caused one to finally scream enough and give in. It might not be obvious and just show up as a crack in the side of the bush.
                      ...and when you're done check out the car. Be very wary of a crack in the bush...
                      ....and I'll get my coat.
                      MY10 Golf 118tsi DSG | MY07 Polo GTI
                        ........Ahhhhh
                        very deep gutters in this place I see.
                          just had a chat to my mechanic and he reckons its a callapsed Bush or wheels bearing, But if you jack it up it should be pretty obvious
                            Nicely ask Chris/Pete/Dean to pop it on the hoist. They'll be able to tell quick smart if the bushes need replacing.
