Brisbane Polo Dyno Day Results - 25 August 2012
  • Brisbane Polo Dyno Day Results - 25 August 2012
    Guys, PM me your costs so I can add it here.
    Data Summary
    Owner KW NM $ Spent IT Start Run 1 IT End Run 1 IT Start Run 2 IT End Run 2 IT Start Run 3 IT End Run 3
    Eddy 161.297 358.956 26 44 34 56 42 64
    Jasn78 156.209 366.340 33 49 39 62 48 69
    VWIndahouse 156.319 348.637 26 45 34 52 30 50
    Sharkie 151.603 312.014 3,600 27 40 35 51 39 57
    Leitch 141.776 303.048 27 32 32 37 34 40
    Spraycanmansam 136.099 305.284 33 78 39 85 46 88
    Gotboost? 99.695 231.059 300 50 71 56 71 66 78
    Intercooler Performance - Intake Temps
    Comment: We spent a bit of time between runs 2 and 3 of VWIndahouse's Polo to get the temps down again for run3, as seen in the full logs which distorts the IT comparison a bit.
    However looking at the increase in temps in each run the performance order is:
    1. Forge - Leitch - kept temp increases amazingly low through all 3 runs.
    2. Ebay - Sharkie - outperformed the SEAT by a few degrees consistently across all 3 runs.
    3. SEAT - VWIndahouse - performed better than the APR by a few degrees consistently across all 3 runs.
    4. APR - Eddy - worst of the brand names in increase in each run.
    5. Ebay - Jasn78 - at least it is better than stock
    6. Stock - Spraycanmansam & GotBoost? - it sucks
    The Forge, incidentally was also the quickest to return to low temps. And the Ebay coolers of Sharkie and Jasn78 are of different manufacturers.
    NB: To get an idea of the boost, subtract 1000 (std air pressure) and then divide by 1000. Therefore 2400mbar = 1.4bar boost
    Eddy's Specs and Result.
    Eddy's Polo's specs:
    Item Description
    ECU APR Stg2
    Intake PD160
    Filter Jabbasport Cone
    MAF Stock
    Diverter APR R1
    Diverter Spring N/A
    TIP Forge
    Turbo K04
    Exhaust Manifold Stock
    Downpipe APR
    Cat High-flow
    Rear silencer APR
    Intake Manifold Stock
    Intake Manifold Gasket Stock
    Intercooler APR
    Intercooler hose APR
    Clutch EVO
    Flywheel SMF light weight
    Crank Pulley Stock
    Fuel Pressure Regulator Bosh 4 Bar
    Fuel Pump APR
    SAI Pump Stock
    N249 Valve Stock
    N75 Valve Stock
    N112 Valve Stock
    Spark Plugs Stock
    Key Data Run 1
    RPM Boost Req Boost Actual
    mbar mbar RPM Intake Temps AFR Boost Bar
    1760 1630 1350 1880 26 0.992 0.35
    1800 1640 1370 2240 26 0.984
    2160 1840 1480 2600 26 0.977
    2480 2020 1750 2960 27 0.961
    2840 2230 2220 3240 27 0.938 1.22
    3160 2350 2540 3560 27 0.906
    3440 2430 2520 3880 27 0.867 1.54
    3800 2480 2450 4240 29 0.852
    4120 2500 2420 4560 30 0.86
    4480 2400 2420 4840 33 0.828
    4880 2390 2320 5200 34 0.836
    5120 2290 2210 5600 37 0.867
    5480 2130 2180 5920 39 0.844
    5760 2020 2090 6200 40 0.836 1.0
    6080 1940 2000 6520 43 0.883
    6480 1950 1990
    Key Data Run 2
    1880 1700 1130 1800 34 0.992
    1760 1640 1300 1800 35 0.875
    1800 1660 1390 1760 35 0.852
    1800 1650 1430 1760 36 0.86
    2080 1800 1500 2160 36 0.86
    2400 2020 1810 2520 36 0.875
    2720 2180 2280 2840 37 0.883
    3040 2360 2520 3120 38 0.852
    3360 2440 2470 3480 39 0.86
    3680 2500 2480 3800 39 0.852
    4000 2550 2490 4120 40 0.899
    4360 2490 2490 4440 42 0.844
    4720 2450 2430 4800 45 0.86
    5040 2370 2260 5120 47 0.844
    5320 2240 2280 5480 50 0.805
    5680 2080 2200 5760 52 0.75
    6000 1980 2080 6120 54 0.75
    6360 1800 2020 6400 56 0.75
      Eddy's Results continued ....
      Key Data Run 3
      1760 1670 1440 1760 42 0.867
      1800 1660 1480 1760 42 0.86
      1800 1670 1490 1760 42 0.867
      1760 1660 1500 1760 42 0.867
      1920 1750 1530 2080 42 0.867
      2320 1970 1780 2440 44 0.844
      2640 2160 2230 2760 45 0.867
      2920 2310 2500 3080 45 0.875
      3280 2430 2480 3360 45 0.86
      3600 2520 2500 3720 47 0.875
      3960 2550 2480 4040 48 0.875
      4280 2550 2470 4360 50 0.852
      4600 2510 2440 4680 51 0.867
      4880 2450 2320 5080 53 0.844
      5280 2260 2150 5360 56 0.805
      5520 2140 2130 5720 58 0.75
      5920 2010 2050 6000 60 0.75
      6240 1980 2030 6360 63 0.75
      6480 1820 2020 6440 64 0.75
        Jasn78's Specs and Results
        Item Description
        ECU Custom Code
        Intake Open Pod
        Filter Open Pod
        MAF Stock
        Diverter Forge DV008
        Diverter Spring Yellow
        TIP Forge
        Turbo Stock K03S
        Downpipe 2.5" Custom
        Cat High-flow
        Rear silencer Custom
        Intercooler FMIC - Custom
        Intercooler hose Forge
        Clutch ECS
        Flywheel ECS light weight - 14lbs
        Crank Pulley Stock
        Fuel Pressure Regulator Stock
        Fuel Pump APR
        SAI Pump Deleted
        N249 Valve Deleted
        N75 Valve Deleted
        N112 Valve Deleted
        Spark Plugs Stock - NGK PFR6Q
        Ignition Coils 2.0 TSI
        Key Data Run 1
        RPM Boost Req mbar Boost Actual mbar RPM Intake Temps AFR Boost Bar
        1760 1640 1470 1760 33 0.867 0.47
        2080 2080 1570 2160 32 0.836
        2400 2280 1880 2520 32 0.828
        2720 2370 2260 2840 32 0.828
        3040 2340 2510 3160 32 0.844 1.51
        3360 2240 2510 3480 33 0.821
        3720 2230 2520 3800 33 0.821 1.52
        4040 2290 2420 4120 34 0.821
        4360 2230 2340 4440 36 0.821
        4680 2180 2240 4800 37 0.828
        5040 2150 2130 5120 39 0.813
        5320 2110 2150 5480 41 0.821
        5680 2030 1960 5800 43 0.828
        6000 1950 1920 6120 45 0.813 0.92
        6320 1920 1850 6440 48 0.821
        6480 1920 1850 6440 49 0.875
          Jasn78's Results Continued
          Key Data Run 2
          1760 1620 1510 1840 39 0.844
          2120 2160 1630 2240 39 0.836
          2440 2320 2000 2560 40 0.821
          2760 2370 2390 2880 42 0.828
          3080 2350 2540 3200 43 0.828
          3400 2250 2540 3560 45 0.821
          3720 2270 2480 3840 46 0.813
          4080 2310 2400 4160 48 0.813
          4400 2260 2330 4520 50 0.821
          4760 2230 2200 4840 51 0.821
          5080 2170 2080 5200 53 0.844
          5400 2100 2110 5520 54 0.805
          5720 2040 1980 5840 56 0.844
          6040 1950 1930 6160 58 0.836
          6400 1920 1820 6480 60 0.821
          6480 1900 1900 6600
          62
          1
          Key Data Run 3
          1800 1610 1440 1800 48 0.828
          1760 1610 1520 1760 48 0.891
          1800 1640 1540 1800 48 0.844
          2120 2150 1630 2200 49 0.828
          2440 2330 1970 2520 50 0.828
          2760 2410 2370 2880 51 0.821
          3080 2380 2540 3200 53 0.828
          3360 2290 2540 3520 54 0.821
          3720 2300 2540 3880 56 0.813
          4080 2350 2500 4200 57 0.813
          4360 2280 2360 4520 59 0.821
          4720 2240 2250 4840 61 0.828
          5040 2190 2130 5120 62 0.828
          5400 2120 2140 5480 63 0.828
          5720 2050 1990 5840 66 0.852
          6040 1950 1950 6120 67 0.828
          6360 1920 1890 6480 68 0.828
          6440 1920 1940 6480 69 0.938
            VWIndahouse's Specs and Results
            Item Description
            ECU Current Custom Code Stg 2
            Intake 3"CAI Duct
            Filter Modshack VTDA K&N Pod
            MAF Stock
            Diverter Forge 007
            TIP Forge
            Turbo Stock K03S
            Exhaust Manifold ATP + HPC Coating
            Cat High-flow
            Rear silencer Miltek 2.5" Catback
            Intake Manifold Gasket Phenolic
            Intercooler SEAT Sport
            Clutch ECS
            Crank Pulley ECS lightweight
            Fuel Pressure Regulator Bosch 4bar
            Fuel Pump APR
            SAI Pump Deleted
            N249 Deleted
            N75 Valve Stock
            N112 Valve Deleted
            Spark Plugs NGK BKR7EKT
            Ignition Coils Stock
            Key Data Run 1
            RPM Boost Reqd mbar Boost Actual mbar RPM Intake Temps AFR Boost Bar
            1760 1630 1520 1800 26 0.86 .52
            2080 2110 1640 2200 26 0.836
            2400 2250 1980 2520 26 0.821
            2720 2340 2330 2840 27 0.821
            3040 2300 2450 3160 27 0.821 1.45
            3400 2210 2450 3480 27 0.828
            3680 2230 2410 3800 27 0.813 1.41
            4040 2280 2360 4160 29 0.828
            4360 2220 2220 4440 30 0.828
            4720 2160 2210 4800 32 0.813
            5040 2110 2120 5120 33 0.828
            5360 2080 2020 5480 36 0.828
            5680 2010 2020 5800 37 0.821 1.02
            6000 1920 1890 6160 39 0.821 0.89
            6360 1900 1910 6480 42 0.821
            6480 1890 1860 6480 45 0.821
              VWIndahouse's results continued
              Key Data Run 2
              1800 1610 1550 1960 34 0.891
              2200 2140 1780 2320 34 0.836
              2520 2330 2170 2640 36 0.828
              2840 2350 2470 2960 36 0.821
              3160 2300 2480 3280 36 0.821
              3520 2210 2460 3600 37 0.821
              3880 2270 2420 3920 38 0.813
              4160 2290 2370 4280 39 0.813
              4480 2210 2270 4640 39 0.828
              4800 2170 2150 4920 42 0.828
              5160 2120 2180 5240 45 0.821
              5480 2080 2040 5560 46 0.813
              5800 2020 1970 5920 48 0.821
              6120 1920 1930 6280 50 0.813
              6480 1890 1910 6440 52 0.821
              Key Data Run 3
              1800 1630 1570 1760 30 0.906
              1880 1670 1580 2040 30 0.891
              2240 2180 1850 2360 30 0.844
              2600 2350 2240 2680 31 0.836
              2960 2360 2490 3000 31 0.828
              3200 2290 2470 3320 31 0.828
              3560 2210 2430 3640 32 0.821
              3880 2280 2370 4000 33 0.821
              4200 2270 2300 4360 34 0.821
              4520 2200 2270 4640 36 0.821
              4840 2150 2150 4960 37 0.836
              5200 2110 2090 5320 39 0.828
              5520 2060 2030 5640 42 0.821
              5840 1990 1960 6000 45 0.821
              6200 1910 1900 6280 48 0.828
              6480 1890 1860 6480 50 0.828
                Sharkie's Specs and Results
                Item Description
                ECU APR Stg1 V2
                Intake PD160
                MAF Stock
                Diverter Forge Clone
                Diverter Spring Yellow + 1 shim
                TIP Forge
                Turbo Stock K03S
                Cat High-flow
                Rear silencer Stock
                Intercooler hose Stock
                Clutch Stock
                Flywheel Stock
                Crank Pulley Stock
                Fuel Pump Stock
                SAI Pump Stock
                N249 Valve Stock
                N75 Valve Stock
                N112 Valve Stock
                Key Data Run 1
                1800 1660 1440 1760 27 0.992 0.44
                2200 1900 1580 1960 27 0.977
                2520 2080 1780 2320 27 0.961
                2840 2070 2050 2640 27 0.922
                3200 2080 2100 2960 28 0.867 1.1
                3520 2080 2040 3280 28 0.813
                3840 2100 2080 3600 29 0.844
                4160 2100 2060 3960 30 0.844
                4520 2050 1990 4280 30 0.828
                4840 2010 1960 4600 32 0.844
                5160 1930 1930 4920 33 0.828
                5480 1840 1970 5280 35 0.821 0.97
                5840 1790 1790 5600 36 0.821
                6160 1780 1770 5920 37 0.797
                6480 1790 1810 6280 39 0.797
                6440 1470 1850 6480 40 0.821 0.85
                  Sharkie's Results Continued
                  Key Data Run 2
                  1760 1640 1430 1800 35 0.821
                  1800 1670 1440 2000 35 0.813
                  2240 1930 1650 2360 36 0.797
                  2560 2100 1930 2680 36 0.828
                  2880 2110 2140 3000 37 0.821
                  3200 2110 2110 3320 37 0.813
                  3520 2110 2110 3640 39 0.821
                  3880 2140 2100 3960 39 0.821
                  4200 2110 2080 4320 40 0.813
                  4520 2080 2040 4640 42 0.813
                  4840 2030 2030 5000 43 0.821
                  5160 1950 1980 5280 45 0.828
                  5520 1870 1910 5640 46 0.813
                  5840 1830 1780 5960 48 0.805
                  6200 1810 1810 6320 49 0.821
                  6480 1820 1840 6480 51 0.813
                  Key Data Run 3
                  1760 1660 1470 1760 39 0.821
                  2000 1780 1520 2120 39 0.813
                  2360 2020 1780 2440 40 0.821
                  2680 2130 2080 2800 42 0.828
                  2960 2140 2130 3040 42 0.821
                  3320 2160 2190 3440 43 0.821
                  3640 2160 2160 3760 44 0.821
                  3960 2180 2150 4120 45 0.813
                  4280 2130 2110 4400 46 0.805
                  4600 2090 2130 4760 48 0.813
                  4960 2020 1990 5120 49 0.813
                  5280 1940 1970 5400 50 0.805
                  5600 1870 1880 5720 51 0.821
                  5920 1820 1770 6080 53 0.813
                  6280 1820 1880 6360 54 0.782
                  6480 1820 1840 6480 57 0.766
                    Leitch's Specs and Results
                    Item Description
                    ECU APR Stg1 V2
                    Intake BMC CDA
                    Filter BMC CDA
                    MAF Stock
                    Diverter Forge DM008
                    TIP Forge
                    Turbo Stock K03S
                    Downpipe Stock
                    Cat Stock
                    Rear silencer Stock
                    Intercooler Forge FMIC
                    Intercooler hose Forge Hose
                    Clutch ECS
                    Crank Pulley Stock
                    Fuel Pump Stock
                    SAI Pump Deleted
                    N249 Valve Deleted
                    N75 Valve Race
                    N112 Valve Deleted
                    Key Data Run 1
                    1760 1640 1360 1760 27 0.852 0.38
                    1920 1710 1380 1800 27 0.852
                    2320 1930 1580 2080 27 0.86
                    2600 2060 1810 2400 27 0.86
                    2920 2090 2080 2720 27 0.86 1.08
                    3240 2110 2290 3040 27 0.86 1.29
                    3560 2130 2170 3360 27 0.875
                    3920 2150 2130 3680 27 0.86
                    4240 2120 2130 4000 27 0.86
                    4640 2050 2040 4360 27 0.852
                    4920 2000 1980 4680 27 0.852
                    5200 1940 1890 5000 27 0.852
                    5560 1880 1790 5360 28 0.852
                    5880 1810 1780 5680 29 0.86
                    6200 1750 1690 6040 30 0.844
                    6520 1710 1710 6320 30 0.86
                    6040 1000 1740 6480 32 0.86 0.74
                      Leitch's Results Continued
                      Key Data Run 2
                      1760 1650 1380 1760 32 0.86
                      2040 1810 1450 2160 32 0.844
                      2400 2010 1670 2520 32 0.852
                      2720 2090 1920 2880 32 0.86
                      3080 2120 2170 3240 32 0.852
                      3360 2130 2310 3480 32 0.852
                      3680 2140 2210 3840 32 0.86
                      4040 2170 2180 4160 33 0.86
                      4360 2110 2120 4480 33 0.852
                      4680 2050 2030 4840 33 0.867
                      5000 1980 1930 5120 33 0.852
                      5360 1920 1860 5480 34 0.852
                      5680 1870 1860 5800 35 0.867
                      6000 1800 1760 6120 36 0.821
                      6320 1750 1720 6440 36 0.782
                      6480 1730 1710 6440 37 0.75
                      Key Data Run 3
                      1760 1650 1410 1760 34 0.86
                      1800 1660 1420 1760 34 0.852
                      2040 1810 1480 2200 35 0.852
                      2400 2010 1710 2520 35 0.852
                      2720 2090 1970 2880 36 0.86
                      3040 2120 2210 3160 36 0.86
                      3400 2130 2280 3480 36 0.867
                      3680 2150 2230 3800 36 0.867
                      4040 2170 2200 4120 36 0.844
                      4400 2090 2070 4480 36 0.852
                      4680 2050 2030 4800 37 0.867
                      5040 1980 1970 5120 37 0.836
                      5360 1930 1950 5440 38 0.789
                      5680 1870 1810 5800 39 0.805
                      6040 1800 1760 6120 39 0.75
                      6360 1750 1710 6440 39 0.75
                      6480 1730 1740 6480 40 0.75
                        Spraycanmansam's Specs and Results
                        Item Description
                        ECU APR Stg1 V2
                        Intake PD160
                        Filter Stock
                        MAF Stock
                        Diverter
                        Diverter Spring N/A
                        TIP Stock
                        Turbo Stock K03S
                        Downpipe Miltek Turbo Back 2.5
                        Cat Miltek Turbo Back 2.5
                        Rear silencer Miltek Turbo Back 2.5
                        Intercooler Stock
                        Clutch Stock
                        Flywheel Stock
                        Crank Pulley Stock
                        Fuel Pump Stock
                        SAI Pump Stock
                        N249 Valve Deleted
                        N75 Valve Stock
                        N112 Valve Stock
                        Key Data Run 1
                        1760 1670 1380 1760 33 0.852
                        1960 1750 1410 2120 33 0.844
                        2320 1980 1710 2440 33 0.86
                        2640 2090 2110 2760 33 0.86
                        3000 2120 2230 3080 35 0.86
                        3320 2120 2140 3400 37 0.867
                        3640 2130 2130 3720 40 0.86
                        3960 2150 2110 4080 45 0.86
                        4320 2100 2120 4400 50 0.844
                        4640 2080 2050 4720 54 0.867
                        4960 2020 2020 5040 58 0.86
                        5280 1950 1980 5360 63 0.86
                        5600 1890 1910 5720 67 0.844
                        5920 1810 1850 6040 71 0.86
                        6280 1730 1830 6360 75 0.844
                        6480 1690 1760 6480 78 0.86
                          Spraycanmansam's Results Continued
                          Key Data Run 2
                          1760 1680 1460 1760 39 0.86
                          2080 1850 1550 2160 40 0.852
                          2400 2020 1920 2520 41 0.852
                          2720 2110 2310 2840 42 0.86
                          3040 2140 2280 3120 45 0.86
                          3360 2150 2210 3480 48 0.867
                          3680 2180 2180 3800 51 0.86
                          4040 2210 2190 4160 56 0.86
                          4360 2160 2170 4480 61 0.86
                          4680 2070 2130 4800 66 0.86
                          5080 1980 2030 5160 69 0.86
                          5400 1900 1930 5520 74 0.86
                          5720 1820 1850 5840 78 0.797
                          6040 1710 1780 6160 80 0.75
                          6360 1610 1690 6480 84 0.75
                          6440 1570 1580 6440 85 0.75
                          Key Data Run 3
                          1760 1680 1480 1800 46 0.86
                          2080 1870 1590 2200 46 0.86
                          2440 2060 1970 2560 47 0.852
                          2760 2130 2390 2880 48 0.844
                          3040 2160 2210 3160 50 0.867
                          3360 2180 2180 3480 53 0.86
                          3720 2200 2170 3880 57 0.852
                          4040 2220 2190 4160 61 0.86
                          4400 2150 2150 4480 64 0.86
                          4720 2060 2070 4840 69 0.86
                          5040 1980 1970 5160 72 0.867
                          5360 1900 1910 5480 76 0.805
                          5720 1830 1830 5800 80 0.75
                          6040 1710 1760 6120 84 0.75
                          6360 1620 1720 6440 85 0.75
                          6480 1550 1610 6440 88 0.821
                            GotBoost?'s Specs and Results
                            Item Description
                            ECU Stock
                            Intake Stock
                            Filter Open Pod
                            MAF Stock
                            Diverter APR R1
                            Diverter Spring N/A
                            TIP Stock
                            Turbo Stock
                            Downpipe Stock
                            Cat Stock
                            Rear silencer Stock
                            Intercooler Stock
                            Clutch Stock
                            Flywheel Stock
                            Crank Pulley Stock
                            Fuel Pump Stock
                            SAI Pump Stock
                            N249 Valve Stock
                            N75 Valve Stock
                            N112 Valve Stock
                            Key Data Run 1
                            1760 1680 1410 1800 50 0.953
                            2000 1850 1470 2120 50 0.938
                            2320 1800 1800 2440 50 0.93
                            2640 1760 1930 2720 51 0.945
                            3000 1650 1720 3080 51 0.953
                            3320 1660 1670 3400 52 0.938
                            3640 1670 1650 3720 54 0.945
                            3960 1670 1650 4080 56 0.945
                            4280 1670 1650 4400 58 0.93
                            4640 1640 1650 4720 60 0.938
                            4960 1560 1580 5040 63 0.938
                            5280 1520 1540 5400 64 0.945
                            5600 1490 1490 5720 67 0.922
                            5960 1400 1420 6040 69 0.828
                            6280 1350 1370 6400 69 0.813
                            6480 1300 1310 6480 71 0.805
                              GotBoost?'s Results Continued
                              Key Data Run 2
                              1760 1690 1410 1760 56 0.945
                              1920 1820 1440 2040 56 0.922
                              2280 1800 1760 2400 57 0.938
                              2600 1810 1950 2680 57 0.953
                              2920 1700 1730 3040 57 0.938
                              3280 1690 1680 3400 58 0.938
                              3600 1690 1690 3680 59 0.938
                              3920 1700 1700 4040 61 0.938
                              4280 1700 1700 4360 63 0.922
                              4600 1680 1660 4680 64 0.86
                              4920 1600 1630 5040 66 0.836
                              5240 1550 1570 5360 67 0.805
                              5560 1510 1520 5720 69 0.774
                              5920 1430 1460 6040 69 0.789
                              6240 1370 1400 6360 71 0.758
                              6480 1310 1300
                              Key Data Run 3
                              1760 1680 1450 1760 66 0.938
                              2120 1790 1600 1840 66 0.938
                              2480 1840 1970 2280 66 0.945
                              2760 1780 1820 2560 67 0.938
                              3120 1720 1740 2880 67 0.914
                              3440 1720 1720 3200 67 0.883
                              3760 1730 1710 3560 68 0.828
                              4120 1730 1710 3880 69 0.805
                              4400 1730 1700 4200 69 0.789
                              4760 1660 1690 4520 69 0.75
                              5080 1590 1610 4840 72 0.75
                              5400 1550 1570 5200 72 0.75
                              5720 1500 1520 5520 74 0.75
                              6080 1410 1400 5840 75 0.75
                              6400 1330 1350 6200 76 0.75
                              6480 1320 1310 6520 78 0.75
