Cold Feed Induction Kit on Ebay
  • #16
    Originally posted by leitch View Post
    The water filler neck does restrict things a little, and I considered quite seriously just ripping the washer bottle out and trying to fit a mk4 or 6n bottle up in the engine bay somewhere. That said, my ducting is 82mm diameter and fits down (with a bit of skin off knuckles) without too much hassle. It would be easier if there was more room, but once you cut the battery tray down (and put a smaller battery in), you quickly find a lot more room to move.
    Thanks mate.
    I went down to have a quick look but running out of light. It looks like its do-able though even with the optima battery.
    I should be able to move to the left far enough to cut away part of the battery tray to fit the tubing down.
    Looks like I might have to order one of the kits.
    p.s. I looked through your flickr link to get more pics of your car. Noticed you use a Synesso.
    What are they like to use. I use a Kees Van Der Westen, Mirage.
    • #17
      if you can change the orientation of your battery so it runs front-back rather than left-right is makes for a lot more room, too.
      The Synesso is actually at a friends cafe. Good to hear you're using a Mirage, though - we use a KVDW Spirit at my work which has been awesome. Dutch pride
      '16 Octavia RS Wagon
      Past - '07 Polo GTI
      '08 RenaultSport Clio 197
