Eddy you animal
If you are in a hurry boss , try studs and nuts, even a tack with stick weld tack , if you need to loosen for any reason then a tack will break off with force , ive thought of this many times. Studs and nuts are a common fix on the big dinner plate turbos, even to a point rethreading the turbo. Im just taking a wee bit longer with mines as i would like to see a simpler fix.
Jmac
If you are in a hurry boss , try studs and nuts, even a tack with stick weld tack , if you need to loosen for any reason then a tack will break off with force , ive thought of this many times. Studs and nuts are a common fix on the big dinner plate turbos, even to a point rethreading the turbo. Im just taking a wee bit longer with mines as i would like to see a simpler fix. Cheers
Jmac
The turb pretty much hangs off the manifold the same way, this Golf is untouched, pretty much virginal in every way, but was loosing boost so i went through it, fixed some vac lines and thought i would check the turbo bolts and loose as a goose. Had a few chipped Polos loose too so no real trend to be honest. My idea is very much to stop any turn the bolt be it 16mm head or 17mm. I was going to go studs and brass nuts if this fails. Ive lock wired a K04 that came loose and that was 6mths ago. Saw it last week lockwire still very nice and taught. Hmmm
