turbo options
  • turbo options
    Hi guys,
    I have been buying up some stuff, and I an now starting to look at turbos, again for my 9n3 pog.
    I have done some research, but I thought I would put it out to you guys as well
    The debate is between the frankenturbo, k04 or the GT28RS.
    Pros and cons on all three.
    Clint
    Polo 9n3 GTI
    Frankenturbo K04 well nice spooling time, not enough power, cheap, OEM location
    GT28, Lots of power, takes a while to spool, costs more $$$, might need a engine rebuild soon
    MODS- TOO MANY
      That's the concern I have...the gt seems awesome, and certain companies like revo claim they got it down pat and very safely, yet others say this is too big, and will necessitate an engine rebuild very soon...hearing so much mixed messages...that's why it good to get unbiased comments from you all
      Polo 9n3 GTI
        GT28 is not really that big
        Another good option a bit smaller is the IHI turbo, can be found on WRX's
        1.8T 20v IHI Kits - JBS
        MODS- TOO MANY
          I would suggest a Franken or JBS04 with E85 tune. That way no lag and even more power than the garrett and safe for the engine. Although rods would be a great idea. Stock position for your new 3" DP too
            Thanks guys, always appreciate your advice
            Polo 9n3 GTI
              Hoyhoy.
              Anthony, any more info or links on this, please.
              Hooroo.
                As you may have seen from another thread, I'd estimate the cost of a new K04 install at 2-3k
                A hybrid turbo would run 3-5k
                A BT would run 4-10k
                Very loose numbers
                A few things to keep in mind are when the power is going to be used and how to get it down. I've found a lot more traction with coil overs, wider wheels, better tyres and sway bars. I think if you wanted big power a LSD is going to be very worth while.
                There are a many supporting mods that accompany the turbo itself, the estimates above factor in some of these parts.
                If you have not read the BT build on Polo UK forum or Badgers custom hybrid tread for his Lupo, might give some insight as to what is possible.
                  Our resident VW specialist (JMac) told me to steer clear of anything larger than a K04 untill I'm ready for an engine rebuild .... Whilst we have a 1.8 20V T, not all 1.8 20V Ts were created equal ..... VW skimped on the internals on the BJX a bit apparently. (Also the reason any dyno of a MK4 GTI with bigger turbo is pointless as a comparison as the MK4 had a "better" engine)
                  So if you want to go larger than a K04 in a Polo, get ready to spend $$$ on strenghtened internals.
                  Hence the reason I'm going K04 1st and then later larger when the car has done enough kms to warrant a full rebuild on the engine and internals. Forged pistons, rods and other bits need to be upgraded to run a GT reliably for more than a few 1000 kms.
                  I beleieve a K04 can be had, installed for less than $2500 including software ...... With other mods I'm expecting 160kw atw then. Problem is that is the level where clucth and other drivetrain components need to be done as well.
                  Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2018 MY18 Golf 110TSI (150TSI) Trendline manual White2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
                    Good info.
                    If you can pick up the parts for less than $1300, you're doing well (assuming only a snail and fuel reg). Tunes start at around $750, this leaves a few hundred for install, sounds pretty reasonable. Probably not a huge job, it's supposed to be a 'straight swap'.
                      Originally posted by Eddy View Post
                      Hoyhoy.
                      Will post up a heap of recent test articles from Hot 4's and Fast Fours and Rotories on Monday when I get access to a scanner at work mate. In the mean time check out Vortex for examples relating to the 1.8t VWVortex.com - E85 + 630s + Walbro Inline = 18 Gurus, Come all.
                      Basically E85 has been heralded as the miracle fuel. All the Internationl drift and time attack cars are moving to it but it's only good for forced induction. You only need to at least double your current injector rate, get a serious pump set up (I would go with a small surge tank for your insane track work mate) and tune. Now if you only use the fuel occasionally you probably wont need to go to a teflon lines but its a good idea. May seem like a bit of effort and spent but bang for buck this upgrade will net you the biggest gain over anything. And best of all its rated as safe as Methonal and safer than Avgas and 110 octane race fuel for engine detonation protection. And out performs them all in terms of power increase.
                      We are not talking 10-20 atwkw increase either it's more like 40-60 depending on set up of a 4 banger. And best of all you can get it at the pump at some Caltex and ELF servos and the number is set to rise and it's cheap as.
                        Oh and grab some Motive DVD's Eddy from http://motivedvd.com/motive/ right up your ally mate and a heap of timeattack action at Wakey. Only $50 for the first box set of 5 dvd's. Covers world and Australian time attack procomp stuff.
                          Interesting, does it make sense that it could be used with K03?
                            Yes mate, have a look on vortex.
                              I'm reading, but it's all a bit odd to me. Haven't been on Vortex in a while...
                              So, you change over the injectors, add a bigger fuel pump, add a bigger fuel reg and.... Pray?
                              Has anyone with a polo / Cupra done it?
