Pog wars - episode i
  • #16
    Originally posted by bfeboi View Post
    Couldn't you refer to the results from the previous dyno day hosted by fuzion?
    Yes mate very relevant but not really good for comparison purposes. For example just from looking at you signature I have over 100nm atw more than you with similar mods. Is that true?? Probably not, but every dyno is different so it has to be the same dyno, same operator, same day, same settings etc.
    Originally posted by spraycanmansam View Post
    I'm in
    Thanks mate added to Pog wars!
    Originally posted by leitch View Post
    If you want to update that, it should be APR stage ~2 come the dyno day.
    Cheers!
    Originally posted by jasn78 View Post
    I know of someone with a stock GTI, "will put a note under his windscreen"
    lol do it!
    Ill be there.
    But rather than push it as a Dyno Challenge, I think we should label it as a return on mod exploration session. No 2 Polos in Brisbane (the tuned ones) are the same these days.
    It should be done to show what a combination of mods can deliver. More of a what can be achieved by what ......
    My Polo for instance has an APR chip, but every other "power" component is non APR. So is that APR Stg1 for me? Stg2?
    We should list power mods individually in the break down.
    ie Sharkie, APR ECU, custom FMIC, custom DP, Forger DV, Forge TIP, PD160, K&N, $spent on power mods, kw atw
    even pulleys, flywheels, etc should be listed.
    I'm interested in what works and what is just a waste of money .....
    Sorry mate the "challenge/pogs wars" terminology was for a bit of fun so don't read too much into it. I was planning on doing up an information form to give out on the day for participants to list mods and other relevant info. Then I was going to compile it all then post with charts and let the "Tuners" go to town and discuss the findings in the hope of gaining some real incite into our little rockets.
    • #17
      do you mind if i come along to spectate? always good to hear some 1.8ts in anger
      • #18
        If there's no bog standard GTI available, I have a standard ECU which will drop into the most standard car on the day, subject to the owners permission obviously.
        • #19
          I should also ask what sort of costs are we looking at? As to me I really couldnt give 2 figs about kw's as everyone may or may not have guess I am more into what I can do down the qtr
          Originally posted by seangti
          • #20
            Sounds good! - Good thing is we have the biggest dyno fan Mainline have built in the country - specifically to get consistent air across the front of the cars (a must for RS6's & Cayenne Turbo's with side mount intercoolers).
            New Workshop | Facebook
            Wall Photos | Facebook
            We can supply raw, uncorrected data (yes - can't be fudged with correction factors etc & hub dyno cant be influenced by tyre pressures & tie down tension) - A good healthy stock car will be needed, we can flash any car to stock if it has no hardware for comparison anyway).
            Need someone to collect all the VCDS logs to go with the results as well.
            Once we get settled, we will organise it.
            Cost? will work on that, I'm guessing $70 a head - that will cover the wages for the day & we will have to get some food organised.
            • #21
              I was thinking if there wasn't a standard car, a Stage 1 with VW software could be run. If it's not APR, you couldn't put his tune back after flashing it to stock.
              My ECU would just go in and run.
              • #22
                Mate I'm sure no one would mind if you jumped on the dyno for another 1.8t perspective, especially because you will have the only Stage III
                car on the day. What engine code do you have bud?
                • #23
                  i dont mind just spectating but if i can get her on the rollers id be chuffed! AGU FTW!!
                  • #24
                    Would be interested to see your Frankenturbo in the MK4 VS My Polo Frankenturbo
                    Not that I will be there lol, just for reference
                    MODS- TOO MANY
                    • #25
                      yeah im interested to see what it puts down aswell, what are your numbers on the frankenturbo? Keep in mind im only running the base file at the moment so i think she still has a little more to give
                      • #26
                        We'll do something about that before then Lito.
                        • #27
                          Def getting too much fuel , drove it again today however i never got to see the injector width, had a mega day surprise suprise, i know you would be getting the file fine tuned so never touched it mate, just made it lower . Tell you what itll give some cars a fright , especially when the fuel is trimmed. I got a BIG smile when i drove it , nice and tund Golf strong, AGU oh yeah!!!and cant wait to my 6N2 done. Many fun Saturdays to be had
                          Ill def be coming to witness this event
                          Jmac
                          Alba European
                          • #28
                            Why are these always in brissie. Comon Melbounians perhaps we could start our own pog wars II.
                            Perhaps we can get someone to sponsor a dyno day in Melbourne....
                            Polo 9n3 GTI
                            • #29
                              Really!! That would be awsome, just let me know when and its yours!
                              Oh and Jimmy, it looks sooo much better a bit lower to the ground, thanks mate! Now to give the back window a really good 'clean' haha
                              • #30
                                No worries Carlos, added to the list mate! Very interested in seeing the characteristics of the AGU bigport.
