Originally posted by max_croft
View Post
Tyre Pressure
With the increase in tyre pressure, the centre of the tyre rises and as described earlier by Preen increases wear. It also means that water moves much much better across the tyre due to the wider surface and higher center, so i can't see why your car would perform worse with higher PSI in the wet when it should be the opposite.80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
Because with the center of the tyre being raised, it may present better water dissipation, but it also means less of the tyre tread face is in contact with the road, which as you know equates to less grip.Originally posted by Golf Houso View PostWith the increase in tyre pressure, the centre of the tyre rises and as described earlier by Preen increases wear. It also means that water moves much much better across the tyre due to the wider surface and higher center, so i can't see why your car would perform worse with higher PSI in the wet when it should be the opposite.
Yes that too, but even the manual suggest to increase PSI during heavy loading or wet weather.Originally posted by Blitzen View PostBecause with the center of the tyre being raised, it may present better water dissipation, but it also means less of the tyre tread face is in contact with the road, which as you know equates to less grip.80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
Ahh, fair enough...I understand about the heavy loading, but that is weird about the wet weather, and goes against everything I have been taught.Originally posted by Golf Houso View PostYes that too, but even the manual suggest to increase PSI during heavy loading or wet weather.
Yeah thats what I thought as well until I few people told me otherwise and I had a look at the manual, at least I thought I read it in the manualOriginally posted by Blitzen View PostAhh, fair enough...I understand about the heavy loading, but that is weird about the wet weather, and goes against everything I have been taught.
One thing to remember also is that different brands recommend differing pressures. I ran my Contis at 40 ... but I'm running the Marangonis at 36. The Marangonis have a stronger sidewall than the Contis and 36 gives a little extra flex. Generally ... I'd take the tire manufacturer's advice ... for optimum performance & wear ... they should know best.
Dave
Ok.....How are you supposed to adjust Castor, and Camber for when you do a wheel alignment?? Just dosn't seem right.Originally posted by MACCAA View PostEr no they're not.Only adjustment on the front is for toe.
Rear is a beam,not "semi independent"? and has no camber/toe adjustment.
