Pommie, I originally contacted ECS and they said there is a MAF for the 225hp Audi TT that has the 3" external and 2.75 internal dimensions which is what you need. Unfortunately they sent the wrong one which was the same as the polo. I never bothered returning it and passed it on to Jimmy. So try ECS again and see if they can measure one for you then ask for the part number and compare with the one I gave Jimmy to make sure it's different.
Either way you are faced with the problem of the TIP being 2.75" external dimension and also the top of the stock air box. The other option is to use a custom 3" MAF housing with a silicone reducer pipe and a 3" pod set up like I just did seen here
http://www.vwwatercooled.org.au/foru...-33911-22.html
