Headlight low/main beam problem
  • Headlight low/main beam problem
    Hi Guru's,
    I've got a problem with my main beam (some call low beam) headlights where they have begun to take a random time to turn on.
    It used to be a couple of seconds delay, then about 10, 20, 30 seconds, now they can take much longer.
    I haven't done any physical inspections yet (just tried searching forums), but has anyone seen this type of behavior before?
    If it was a fuse I thought it would just stop working all together, if it was the bulbs I wasn't expecting them to both be misbehaving.
    I have a 2006 Polo GTI 9N
    Thanks in advance!
    My electrician mate reckons it's likely a relay.
    Anyone know where I can get a Polo GTI parts list or electrical wiring schematic?
      Your not running a HID kit are you?
      Standard Halogen is instant, but HID can have a delay and also takes time to "warm up"
      2016 Golf R, APR Stage 1
      2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
        Both my low beam globes went out together
        I just replaced them and they've been sweet ever since
          Just dropped into see Matt at Camden GTI Campbelltown - he fixed it on the spot!
          Turned out I had a faulty switch, Matt was able to plug in a spare he had and it fixed it straight away. Must've been a faulty relay.
          Brand new switch from VW was around $200, Matt fitted a spare he had for less than half that - thanks!!
            Nope - just running stock - thanks for the suggestion though!
              Amazing how they can both go out within such a close time of each other
                Awesome outcome, Matt is the man...
