Originally posted by RoSonic
View Post
The 3 inch one isn't an uprated one. They are standard on the 8L S3 and TT etc. The std Polo or KO3 turbo'd engines don't need a bigger MAF as they do not have enough volume of air going through them, to need the larger MAFs increased capability to measure.
If you fit a K04 for example, then to get the most power you would need to use bigger injectors, MAF, Fuel pump and FPR. These would basically bring your engine up to 8L S3 specs. It would produce around 270hp if you had a better downpipe and exhaust.
